Tip & How-To about Miscellaneous
How to fix your WIFI signal, and prevent drops in service at home.
Is your WIFI constantly Dropping at Home ? So was Mine.
Check the quality of your WIFI signals at home with your smartphone. Use apps such as WIFI analyzer to see which channels are being used.
If you have a lot of signals from your neighbors, consider choosing a channel that is weakest at your home, so your signal has higher boost.
Also, if you have a lot of wireless remote devices such as a 2.4 Ghz phone, or Non-Bluetooth wireless, Consider setting your WIFI router to a 5 GHz channel.
Older devices might not see 5 Ghz. signals, so make sure that yours does, or better, set up your router to support both 2.4 Ghz and 5Ghz. That way, you split up your available bandwidth on 2 different Channels.
note: Cellphone providers might Snag away the 5Ghz signals in the futur.
Miscellaneous Logo
We just changed to spectrum and chrome cast won’t connect. What should I do
Chromecast receives a wifi signal. Are you still broadcasting a wifi signal? Is SSID the same? Is it the same band. .. 2.4 or 5 g? If the wifi all matches, then you can reset the chromecast by holding the black reset button down for 20-30 seconds. Reinstall the latest google home app on a smartphone and follow the setup instructions on the app.
Dec 14, 2017 | Televison & Video
I have a Westinghouse smart TV and I have the WiFi home but it is not connecting to the internet or netflix what must I do
Hi Samantha
Assuming that the WiFi is working around the house with other devices like iPhone / iPad and other computers?
The Westinghouse TV is just another device connecting to your Home Network via a WiFi Signal. Unless it uses a dedicated Ethernet Cable at the back of the set > to Modem Router Box.
So... the problem would require setting up the Westinghouse smart TV with the necessary settings.
Netflix is just a web site and will become available when the TV connects to your Network & External Internet GateWay.
First, you need to know your WiFi Name & Password.
I find it easier to use the iPhone as a test device to check the WiFi signal and set up details first. To Test Password etc.
There is a helpful tool on the App Store called iNet - Network Scanner - See Below
So... you must find the settings for Network on your smart tv.
Setting the tv for DHCP is allowing it to Automatically search for an internet connection. Thats what most people do.
Just choose your WiFi name (SSID) & Password.
But... you can choose your own IP addresses if you like to keep all your devices on a known address.
Eg. Your Router or Modem Box Gateway address
Each of the other devices have a unique address.
Computer 1
Computer 2
Camera 1
You can use the end numbers between 1 & 255
Your Gateway might also use another IP Group e.g.
Your really only interested in making the last numbers different from each other.
iNet - Network Scanner APP
The iNet Network Scanner and Toolbox for Mac
How to Connect Your SmartPhone to WiFi at Home or the Office
How to Install Wireless Router for Beginners How to Install Wireless...
Oct 14, 2016 | Computers & Internet
When my iWork's is paired with my iPhone 6 splus it plays music for a bit then starts playing a busy signal then plays music for a few seconds then the busy signal again
iPhone 6 not working with hands-free on a Toyot... ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 20, 2014 - I received the iPhone 6 today and registered the device on my Toyota... The iPhone 6 paired with the audio system, but whenever the phone receives a ... I also notice sometimes the vehicle shows 0 signal strength, when in ...Missing: iwork's ‎splus ‎random ‎busy
iPhone 6 dropping WiFi constantly ' Apple Support Communities
Apple Inc.Sep 20, 2014 - Got my iPhone 6 today and it keeps dropping my WiFi signal in my ....kick of wi fi constantly worse part is I was busy listening to music app last ...Missing: iwork's ‎paired ‎splus
Community: Using iPhone ' Apple Support Communities
Dec 25, 2015 | Cell Phones
iphone 4s no network coverage at home
By no network coverage do you mean no cellular signal or can't connect to your home wifi? If wifi trouble push settings button on iphone. Select and turn on wifi. It will search for available wireless networks. Choose your home wifi, should be the strongest signal, most bars. If you don't know your ssid , look on the sticker on the modem. For instance ssid at&t 2345. Once you select your ssid you need to enter password which is also found on the sticker on modem. Enter password and select join. You should now be connected to your wifi. This will always reconnect automatically when you leave and come back home. If not wifi issue, are you just too far from cell tower to get good signal?
Sep 06, 2014 | Apple iPhone Smartphone
I own a new Samsung Ultrabook laptop. It constantly drops the wifi connection or takes it back to LIMITED. I know its not my Wifi because other devices don't drop off.
well it depends on range, and near by electrical noise.
are you at home or at startbucks? just a clue?
get a wifi meter, install it to the book.
then see just how good you think wifi , really is.
i use. APP
it's like wifi radar. shows you the signal strength
the neighbors interference.
are you using the same channels as the neighbors.?
yes, well get off that channel and use another.
are you using G/N wifi ? if not why not.
my neighbors all use defaults, so they are on the low channels
im on the upper.
and i have 2 WIFI smart routers, to make all TV and all wifi work
in home, is home large?
i run a Dlink Dap1525 , it sees your moving about and directs the signal so you. true magic here. Love mine.
Wifi is weak, and has very limited range. unless you plan out the system.
Sep 29, 2013 | Samsung Silver 13.3" Ultrabook...
117 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
