Tip & How-To about Miscellaneous
Pressure washing, is the growing application of underhand water apply. Produced by specially engineered pushes, this apply is a hundred times more powerful than the average water hose. On tangible it is used to eliminate undesirable pattern, percolate gum, and other dust spots. Wood made patios are came back to the look of new wood, gap of greying and exhausted completes. On houses, the appearance of house siding (namely metal and vinyl), is greatly improved by eliminating contamination, pattern, and other signs of neglect.
Miscellaneous Logo
what kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
is there a special rear brake tool for 2008 pathfinder
Yes their is a special tool to wind the rear calipers in and push in at the same time ,if no tool then use a G clamp and apply a bit of pressure then turn piston with a pair of water pump pliers ,better if someone turns the G clamp whilst you turn the piston ,but its easier to buy a cheap tool from the auto factor
Mar 21, 2012 | 2008 Nissan Pathfinder
What is so special about 'Grow-a-Gift'? Gifts really grow and change?!
Yes there are lots of idea's for gifts like photo gifts,photo t shirts,photo mug,corporate gifts etc are used you can easily develop grow of gifts.
Sep 21, 2010 | Facebook Apps
How should i wash off my northstar engine?
u can wash it off just be carful around the air intake and dont try to get water in the alternator.
Sep 11, 2009 | 1996 Cadillac DeVille
226 people viewed this tip
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
