Tip & How-To about Dream Maker Spas Dream Maker Ez Spa Hot Tub
How to care for and maintain your Dream Maker spa cover
For a great overview of what you need to know about caring for your hot tub and spa cover, check out this article on Care and maintenance
Tips include:
  1. Stay on top of regular monthly cleaning
  2. Avoid using too much chlorine as it will deteriorate covers faster
  3. Use armor all or some other type of vinyl protectant
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
is there a good website to buy accessories for my hot tub? steps, cover lifter, etc?
i like the brand litehouse. you can see their spa accessories here:
Jan 28, 2013 | Pool & Spa
Foam in hot tub cover broke
The foam in there is available at most insulation or drywall supply houses. It is used for insulating concrete walls, the cover is probably 3 inches thick so you may have to buy 2 sheets to get the thickness you want. The only issue is the cost of the foam may not be much less than a new cover.
Mar 11, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub maintenance
there will be the same amount of basic maintenance on either spa. The difference will be in water chemistry. you definitely want an ozone generator on either spa. Both are awesome Mfg of spas. they both have been around since the 1980's
Ozone will keep the water cleaner, fresher smelling and reduce the total amount of traditional chemicals used in any hot tub.
There are many other solutions for taking care of water chemistry out there without using the traditional types.
some are all natural.
Jan 02, 2009 | Waterway Spa Pump & Hot Tub Pump 1.5"...
445 people viewed this tip
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
Craig Butler
Craig Butler
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
