Tip & How-To about Miscellaneous
Principles of Truck Cleaning
There are different methods available to clean a truck. The method to be used depends on a range of factors including but not limited to:
1 Availability of cleandown equipment and infrastructure
2 Commodity to be loaded Contaminant type in the truck
3 Prior loads Transport company procedures
4 Time available for cleaning
For more information visit our sites
http://mammothtruckwash.com/
Miscellaneous Logo
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
how to conect to wireless network
Wireless connections to the Internet can be achieved by several methods and it depends upon the method of delivery by the Internet Service Provider in your location.
The most common is by DSL and cable, the modems that are used with DSL and cable connection can have a built-in wireless router. Your computer will require a wireless card to connect to the modem/wireless router and the range is restricted to approx. 100 ft depending where the wireless router is located within the building.
The laptop's wireless card can be a built-in device or a plug-in device eg a PCMCIA card or a USB device. and these can also connect to a wifi hot spot in locations such as McDonalds. Star Bucks etc.
There is another method that can connect into the Internet that uses a USB wireless device that connects to a G3 network, bacically a type of mobile transmission and the device is locked into a specific Internet Service Provider. This method gives a wider mobile range (even across states) of connecting to the Internet but usually at a higher cost.
Basically you need to see what the Internet Service Providers offer in your location. Beware of the costs of the various plans they offer in broadband speed, their download limits and the penality for exceeding the limits etc.
When you decide which method you choose, you need to consider setting up your wireless network securely to prevent unauthorized access.
May 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
can siemens speedstream 4200 be used with wifi antenna. do not want dsl.
The Siemens is a DSL modem and doesn't meet with your requirements.
May 02, 2009 | Computers & Internet
128 people viewed this tip
Top Miscellaneous Experts
Rick Oudette
Rick Oudette
Level 1 Expert
Richard Daly
Richard Daly
Level 1 Expert
Dale
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
