Tip & How-To about Acer Revo Computers & Internet
3 Beeps, Pause, 3 Beeps Error Code Fix for acer Revo RL80-UR23
Made a video showing how I fixed the 3 Beeps, Pause, 3 Beeps Error Code on an acer Revo RL80-UR23.
Computers & Internet Logo
RL80 can't boot one short beep?
Sometimes a memory module will go falty. Try taking one out and seeing if it runs. Then try it with the other one and see if it runs. If it runs with one and not the other then you have a faulty memory module. Also if you have any PCI cards that you can remove, it might work with them removed.
Dec 03, 2014 | Acer REVO RL80-UR318 - Core i3 2377M 1.5...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
dell gx 150
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Nov 05, 2007 | Dell OptiPlex GX260 PC Desktop
878 people viewed this tip
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
