Tip & How-To about Home
Replace Toilet Fill Valve Assembly
Made a video showing how I replaced the toilet fill valve assembly.
Home Logo
will not stop filling
press on the flapper and see if the water fills and stops filling. If not replace the fill valve.
replace the flapper if when you force the fill valve closed or shut off the supply water to the toilet and it drains out.
Sep 21, 2013 | Toto Orinigal Replacement Part Thu013p 1...
the water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Oct 26, 2009 | Kohler K-3466-95 San Raphael one-piece...
Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
Toilet fills up slowly
buy a universal fill valve and replace it
Jan 03, 2009 | Home
299 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
