Tip & How-To about iCare Recovery Software iCare Data Recovery Software
How to Restore iPad without iTunes
ITunes can help you solve most of the above issues in most cases, but what if iTunes can't recognize your device when you try to restore iPhone or iPad with it? Or what to do when you intend to factory reset iPad with iTunes to get out of stuck problems without any backups available?
Fortunately, FoneLab for iOS can do all favors for you. Besides, this program provides you more powerful function that can help you recover lost/deleted data from iPad/iPhone without backups in no effort. Download the free trial version and try to restore iPad without iTunes.
Computers & Internet Logo
my iphone is brought from korea and to nepal and iphone does not open only emergency call which is not possible.
hi dear.
You may encounter the following symptoms while updating or restoring your iPhone or iPod touch:
  • iPhone or iPod touch continually restarts but never displays the Home screen.
  • An update or restore did not complete and the device is no longer recognized in iTunes.
  • iPhone or iPod touch stops responding, showing the Apple logo with no progress bar or a stopped progress bar, for over ten minutes.
If this occurs, you can place the device into recovery mode and attempt to restore the device again. If iTunes displayed an alert with an error code, see this article before attempting the steps outlined here.
Note: In certain situations, an iPhone or iPod touch will automatically go into recovery mode after an update or restore issue. If your device is already in recovery mode, you can attempt to restore using iTunes.
Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
  4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:
  5. If necessary, open iTunes. You should see the following "recovery mode" alert:
  6. Use iTunes to restore the device.
  7. If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
    When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup. See this article for more information
Oct 10, 2011 | Apple iPhone Smartphone
my apple iphone 3g is hang .its is showing white scren , signal ,time and battery ..and it is nor switching off on pressing switch off button.. so pls help m. wt should i do..
I would restore the iphone from you last back up. this will reinstall your operating system and insure you do not have a soft ware issue.
Make sure you have the latest version of iTunes installed and running before attempting to update.
Connect your device to your computer.
Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
Select the Summary tab.
Select the Restore option.
When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..." If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new
Aug 08, 2011 | Apple iPhone Smartphone
My daughter set a password for son's iphone 3G and she cannot remember the password, can someone advice me how to unlock the phone
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click restore.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 08, 2011 | Apple iPhone 3G
I keep having to reset my iphone. It is not recognizing the sim card
Firstly try the SIM in another phone if it doesnt work then its a problem with your SIM if it does its the phone try restoring as new...
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
Dec 26, 2010 | Apple iPhone Smartphone
iphone disabled connect to itunes
Here are your instructions from the website below.
Reset your iPhone Passcode:
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number http://www.knowyourmobile.com/appleiphone/apple_iphone_userguides/4684/how_to_password_protect_your_iphone.html Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 28, 2008 | Apple iPhone 3G
206 people viewed this tip
Top iCare Recovery Software Computers & Internet Experts
David Payne
David Payne
Are you an iCare Recovery Software Computer and Internet Expert? Answer questions, earn points and help others
