On a Laptop often you have to disassemble the computer to remove the battery or jump the CMOS reset. On some laptop, like many Dells, and thinkpads the battery can be accessed from one of the slots at the bottom, and it is located deep at one side of the slot. More commonly battery is located on lower side of the motherboard, and to access it you will have to remove the motherboard. Better getting schematics before disassembling the laptop.
Do not disassemble the laptop unless you have done this operation several times before, and you have practice.
Before disassemblying remove battery and unplug the AC adapter. Do not short any pins unless you are sure that you are jumping the CMOS reset pins, even without main laptop battery you can still damage components touching here and there.
The best way to erase CMOS is removing the laptop battery for one minute, thn pputting it back.
This will reset CMOS to factory and erase BIOS settings.
By vidlibprovar Rank: Apprentice Rating: 0%, 0 votes
For IBM Thinkpads, This method will not work on new models. The Security is saved on a seperate chip. This chip can be located anywhere. It may say ATMEL on the chip but there may be a few chips from that company depending on the Board. If there was an easy way to reset bios security then IBM would not be rated as high on security and business solutions. It would be nice if they made a good way for IT profesionals to reset passwords for "right" reasons based on proof of purchase.
