Tip & How-To about Tools & Hardware - Others
LADDER SAFETY.
MANY TIMES I HAVE SEEN W-MEN OR ODD JOB MEN UP A LADDER SOME TIMES 20 TO 30 FEET HIGH ,WITH NOTHING AT BASE OF LADDER EXCEPT THE RUBBER FEET TO STOP THE LADDER SLIPPING AWAY'
SO MY TIP IS , USE TWO BAGS OF SAND OR BALLAST WEDGED UP AGAINST EACH SUPPORTING LEG, BY DOING THIS IT MAY SAVE YOU A LOT OF PAIN OR EVEN DYING YOUNG , GOOD LUCK
RETIRED MAINTENANCE ENGINEER TIP
Tools & Hardware - Others Logo
g5rv lite installation instructions
A G5RV antenna is a popular ham antenna due to its cost, weight and ease of installation. The G5RV is a really a dipole type, that looks like a "T" with the top of the T as the main radiator consisting of a single conductor main radiator and the bottom of the "T" (also radiating on certain bands) consisting of a 2 conductor 450 - 600 ohm "ladder line" that terminates in a fitting that converts ladder line to a coaxial connector.
One of the most popular configurations is the inverted "V". Depending on the version of the antenna, the main radiator will be either 102, 92 or 51 feet long. The ladder line will be 32, 42 or 16 feet (respectively) in length and will require a coax feed length of 70, 70 or 40 feet minimum (again, respectively) to present the proper range of impedences to your manual or auto tuner (the G5RV REQUIRES an external tuner to present an acceptable SWR or impedence match to your transmitter on all bands).
The inverted V requires a mast as high as you can erect, located as close as centered between support sources (trees, buildings, etc.). Ideally, there should be enough room between the mast and the main radiator supports to allow the main radiators to be fully extended. Also, the ladder line should be able to hang straight down without being coiled on the ground at the base. This means you'd need a 32 ~ 42 foot mast at minimum.
The top of the mast will be needed to be fitted with an anchor or hook that will support the center insulator that provides strain relief, splits the ladder line and allows connection of the ladder line conductors to the single conductor main radiators.
Unroll the antenna on the ground. Connect the center insulator to the top section of the mast by the hook. Install "antenna lead stand offs" every 3, 4 or 5 feet. Secure the ladder line to the stand off to keep it from touching / wrapping around the mast.
Use UV resistance parachute cord to connect to and support the main radiator insulator, and pull the slack from the line, from a point as high off the ground as possible. Do the same to the other radiator, trying to match the height above the ground as the first radiator. Go back and forth between the two radiators (or have a helper - so each can be pulled slowly, and evenly together. Inspect the mast to be sure it is still straight. Loosen or tighten the radiator support lines as needed to allow the mast to stand straight.
Secure all lines, connect and run coax to the connector at end / bottom of the ladder line. and connect the opposite end to your antenna tuner connector labeled "ANT". Connect a short coax cable between the transmitter's "ANT" connector and the tuner's "XMIT" connector.
Set xmit power to 5 - 10 watts, transmit and operate the tuner - or set up your radio to use an external auto tuner. Tune for lowest SWR or reflected power. The internal auto tuner on many radios is only good for correcting up to a 3.0:1 mismatch or SWR. The G5RV will present mismatches far in excess of 3.0:1 on certain frequencies and bands.
Jan 12, 2013 | Radio Communications
How many ladders should I put in the cage?
It depends on the bird type and size. If it is a big parrot like African greys or macaws I would put 2-3 ladders. I also recommend having ladders and perches in the birds stand so the bird will be able to stretch their wings and do some exercise.
May 14, 2012 | Birds
my kenmore top loader always shakes acrosss the floor. I stop it during spin cycle and reujust the load. the machine is level on the floor and the feet are dialed in.
is there rubber on the bottom of the feet?also i've seen in laundry rooms at one time or another the vent line on the dryer popped off or had a hole in it and lint got on the floor and under the washer,it finds it's way under the feet,try tilting the washer back and with a steel brush or sand paper clean off the bottom of the feet and see if that helps,also clean the floor under the washer.you may have to replace the rubbers on the feet.good luck
Mar 28, 2011 | Kenmore 22422 Top Load Washer
563 people viewed this tip
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
