Tip & How-To about Miscellaneous
Street Elbow Suppliers
Tube fittings are connectors used for terminating, controlling flow, and changing the direction of tubing in many different steel industries. When purchasing tube fittings, consider its application because this will affect material type, shape, size, dimensions and required durability. Tube fittings are available threaded or unthreaded, in many shapes, styles, sizes, and schedules.
A street elbow suppliers, also called steel ell or service ell is a type of plumbing or tubing fitting intended to join a piece of pipe and another fitting at an angle. The major difference between a street elbow and a regular elbow is the nature of connections on any end. The best advantage of street elbow is that it is easy to connect directly to another fitting without having to use any additional short connecting piece or tool. The street elbows meet standards ASTM and ASME for quality assurance Class means standards related to tolerance, dimensions, thickness, construction, etc.
Miscellaneous Logo
what is the name or number of nonmagnetic stainlessteel ?
It is commonly stated that "stainless steel is non-magnetic". This is not strictly true and the real situation is rather more complicated. The degree of magnetic response ormagnetic permeabilityis derived from the microstructure of the steel. A totally non-magnetic material has a relative magnetic permeability of 1. Austenitic structures are totally non-magnetic and so a 100% austenitic stainless steel would have a permeability of 1. In practice this is not achieved. There is always a small amount of ferrite and/or martensite in the steel and so permeability values are always above 1. Typical values for standard austenitic stainless steels can be in the order of 1.05 - 1.1. SeeComposition effects on the magnetic permeability of austenitic stainless steels
It is possible for the magnetic permeability of austenitic steels to be changed during processing. For example,cold work and weldingare liable to increase the amount of martensite and ferrite respectively in the steel. A familiar example is in a stainless steel sink where the flat drainer has little magnetic response whereas the pressed bowl has a higher response due to the formation of martensite particularly in the corners.
In practical terms, austenitic stainless steels are used for "non-magnetic" applications, for example magnetic resonance imaging (MRI). In these cases, it is often necessary to agree a maximum magnetic permeability between customer and supplier. It can be as low as 1.004.
I hope this helps you
Marty
Jun 19, 2014 | Measuring Tools & Sensors
Can stainless steel rust?
Unfortunately yes, any stainless steel product can get rusty under some circumstances although a stainless steel is much more resistant to corrosion and rust. I suggest you to get stainless steel if you don't want to replace your silverware and kitchen product every couple of months.
Jul 25, 2012 | Camping, Backpacking & Hiking
103 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
