Tip & How-To about Xerox Office Equipment & Supplies
HOW TO CHANGE THE XEROX PHASER 7800 MPT ASSEMBLY
You might have to change this part if you are getting the following errors:
-Mpt is not lifting any paper to the feed rollers
-375.100 Tray 1 Miss Feed
-375.103 Tray 1 Feed Out Sensor Off Jam
-375.212 Tray 1 Nudger Up Down Fault
-(Check condition of feed rollers and make sure no paper or foreign substance are on the paper path)
PART# 059K73151,604K69750
paper will not feed. the lift tray does work. 1.5 to 2 inches of the top of the paper feeds before it stops. when i used count only still get the same problem with
A01 is pickup error. Clean the paper sensor in the paper lifting tray and try. Clean the rubber rollers also.
S. Mohan, Chennai, India
Nov 17, 2011 | Canon DR-9080C Path-Through Scanner
I have a Hp Printer Mfp4345 with error message 13.01.00 I tried changing Rollers,and all the sensors and paper path is in good condition..I noticed that the tray is not lifting and i even replaced Lifting motor..please help me..
In DIAGNOSTICS menu select "paper path sensor test"
Pay attention to E, it refers to "tray 2 pre feed sensor".
You say that you " tried changing Rollers,and all the sensors".
I'm confused, does that mean that you tried and couldn't change the sensors.
You could also have a bad paper tray.
Did you also try and succeed in changing the tray 2 jam access door roller?
13.01.00 means that the pre feed sensor never sensed paper, so either the sensor is bad or the paper never fed out of the tray. Try a different tray.
Apr 11, 2011 | HP LaserJet M4345 MultiFunction Printer
AccelaWriter8200 feed problem
Most likely you will have to replace the feed rollers. 1-800-828-5881 and follow the prompts.
Aug 16, 2008 | Office Equipment & Supplies
paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
850 people viewed this tip
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
