Tip & How-To about Dell 5100cn Laser Printer
Dell 5100CN, 5110CN Developer Replacement
If your Dell 5100cn or 5110cn is having certain print quality issues you may need to replace one or more developers.
This video covers the following part numbers: M6091, G6593, M6090, H6682
Dell 5100cn Laser Printer Logo
my dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
498 people viewed this tip
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
