Tip & How-To about Xerox Phaser Office Equipment & Supplies
HOW TO CHANGE TRANSFER ROLLER ON A XEROX PHASER 7800
Today we will be replacing a Xerox Phaser 7800 transfer roller part# 108R01053
You will have to replace the fuser if you are getting the following errors:
Repeating spots or lines every "54mm" or "2.13 in"
The image quality is very light and missing a lot of color
If the control panel display reads end of life
how to turn off replace fuser on display on xerox 6180
The message is caused by the fuser having had 100,000 pages or so through it.
It will be pretty much worn out, and should be replaced.
The transfer belt also has a similar pagecount limited life, and also the pickup/separation/transport rollers would benefit from replacing (they can get 'flat spots' on them
Jan 31, 2012 | Xerox Phaser 6180N Laser Printer
ERROR CODE PHASER 8560 07,010.43:69551 Replaced Maintance kit
. they replace a certain number of pages printed by the manufacturer data
maintenance kits are easily user installable and come with a fuser assembly, transfer roller, and pickup, or feed/separation rollers.
Apr 11, 2011 | Xerox Phaser 8560DN Laser Printer
fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
759 people viewed this tip
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
