Tip & How-To about Xerox Office Equipment & Supplies
HOW TO CHANGE FUSER ON A XEROX PHASER 7800
Today we will be replacing a Xerox Phaser 7800 fuser part# 115R00073
You will have to replace the fuser if you are getting the following errors:
Error codes: 310.367 - 310.380, 310.382, 310.420, 310.421
Paper jams in fuser
Repeating spots or lines every "84mm"
Toner missing or easy ruboff
If the control panel display reads fuser end of life
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
xerox fuser for Phaser 6300 installed in Dell 5100CN- Fuser ID er
I would only use the part designated by the manufacturer.
Feb 24, 2009 | Dell 5100cn Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
523 people viewed this tip
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
