Tip & How-To about Subaru Cars & Trucks
Subary(2010 Outback) ignition key remote door lock function
My 2010 Subaru Outback (Euro spec) has for a long time been bugged with intermittent functioning of the kemote unloc/lock of the ignition key. I changed the battery several times, mistakenly thinking this was the cause. However, when I disassembled the remote unit of the ignition key, I found that the battery contact for the positive pole had come loose from the printed curcuit Board, given intermittent power to the module.
I turned out that the printed curcuit Board can be extracted by gently prying open the Remote unit holding the battery and the Electronics inside. The battery pole contact can then be soldered back in place as a remedy of the problem. As this had happened to both keys fairly parallely I suspect a production or design flaw. Anyway, soldering it back up saved me a lot of money for potentially replacing both keys/Remotes.
The attached pictures are marked up with repair advise for anyone who wants to give it ago with the soldering iron.
Electronic unit retrieved from key unit
Cars & Trucks Logo
central locking module
clean the ir sender on the remote,check for short curcuit in door wiring,or ignition switch is going bad(security module on ignition switch)
Apr 10, 2015 | 2008 Subaru Outback
how do I remove key from ignition 1997 Subaru outback
Make sure the lever is in park all the way to the left and the battery is ok
Sep 21, 2014 | 1997 Subaru Outback
why won't my 2010 subaru outback wagon interior lights go off unless it's locked
Check your Interior Light Switch what position is it?
The Striker may have lost a Wire. Test EACH DOOR
Apr 09, 2013 | 1999 Subaru Legacy
replacement of battery in 2010 remote for keyless ignition
If you are talking about the Key FOB, most Autozone, Advance, and Oreilys have a remote tester and batteries for the FOB.
Please rate my info.
Nov 13, 2012 | 2010 Subaru Outback
125 people viewed this tip
Top Subaru Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
Are you a Subaru Expert? Answer questions, earn points and help others
