Tip & How-To about Miscellaneous
Super Duplex Pipe Manufacturers
Super Duplex Pipes are mainly developed to be used in extreme stress environments. The properties of this alloy are very high which include, toughness, strength, corrosion resistance to a decent number of organic and inorganic acids. Super Duplex Pipes are similar to the standard duplex types, but they contain a higher content of chromium which enhances the mechanical properties as well as its corrosion resistance. Normally a Super Duplex Pipes contains 25% of chromium, 4% of molybdenum and 7% of nickel. It is particularly suited for warm-water chlorinated environments and acidic, chloric containing systems. Super Duplex Pipes types always show good fatigue strength and that's why they are always much preferred over standard duplex ones.
A pipe is a tubular section or hollow cylinder, usually but not necessarily of circular cross-section, used mainly to convey substances which can flow - liquids and gases (fluids), slurries, powders and masses of small solids. It can also be used for structural applications; the hollow pipe is far stiffer per unit weight than solid members. Om Tubes being Super Duplex Pipe Manufacturers provides you with best quality & services.
Miscellaneous Logo
107 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
