Tip & How-To about Miscellaneous
Carbon Pipe Fitting Manufacturers
Carbon Steel Pipe Fitting Manufacturers are used in pipe systems to connect straight pipe or tubing sections. The main use of fitting is to make the pipe or the tube adaptable to different sizes or shapes. Carbon Steel Pipe Fittings are also used for other purposes such as regulating or measuring fluid flow. The term plumbing is generally used to describe conveyance of water, gas, or liquid waste in ordinary domestic or commercial environments, whereas piping is often used to describe high-performance conveyance of fluids in specialized applications. The term tubing is sometimes used for lighter-weight piping, especially types that are flexible enough to be supplied in coiled form.
To know better about carbon steel, we can compare it with stainless steel. Carbon Steel Pipe Fitting Manufacturers is an alloy of iron and carbon and stainless steel is an alloy of iron and chromium. Carbon steel can rust over a period of time. Stainless steel on the other hand doesn't rust. Carbon steel is hard and wear resistance unlike stainless steel which is softer (knife will not stay sharp for long time). Carbon steel is brittle in nature and stainless steel is non brittle.
Miscellaneous Logo
My van leeks water alot from wear the bottom raideator hose connects to the transmisson . I guess thats wear its connected to? how can it be fixed?
You should be able to replace the sections of tubing (available at the auto parts store)
and use radiator type clamps instead of those cheezy factory ones. If the fitting itself
is leaking, you may take it out and use some teflon tape (white plumbers tape)
to make the fitting more secure. If all else fails, I have retapped these with a
pipe tap by having someone hold a vacuum to pull the chips back, then installed
a brass "hose barb" to threaded pipe fitting in place of the original fitting. The pipe tap
size depends on the fitting size itself. (Last one I did was on a ford and that was 1/4
inch pipe tap). You may need to open the hole to 7/16 inch with a drill (Gently of course).
The auto parts store should carry these items as well, but any hardware store should carry
the taps.
Hope this helps.
Mar 26, 2011 | 1989 Plymouth Voyager
what is the main difference between pipe threads and bolt thread?
pipe threads taper. measurements are different.names are drefferent.pipes are called ips or iron pipe size.bolts are by size and noumber of thread per inch or mm
Dec 06, 2010 | Computers & Internet
81 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
