Tip & How-To about Miscellaneous
Duplex Tubes Manufacturers
Duplex Tubes is basically a hollow cylinder of metal, plastic, glass, etc. for holding or transporting something, chiefly liquids or gases. It conducts the flow of liquids or can also be used for containing electrical wires. The material of which the tube is made may defer. It is generally confused with pipe but there is a big difference in diameters and thicknesses leading to different types of fittings used to connect them. For making joints and connections soldering is used. Sometimes threaded connections are also used as an alternative. These days nylon Duplex Tubes are in great demand in industries and production mills. They have medical applications too as they are widely used as flexible pipes such as breathing Duplex Tubes or Duplex Tubes for IVs in hospitals. Manufacturing of seamless tubing begins with either an extruded hollow tube or a solid bar drilled to our exacting specifications. Duplex Tubes respond positively to cold working techniques. Cold working is done until it reaches the specific size, tolerances, and temper required by the customer. Om Tubes Duplex Tubes have to be cut cleaned and heat treated after each cold working cycle. This makes it prepared for next cold working step. In 21st century Duplex Tubes are used in almost all major factories. There are various grades of Duplex Tubes made of various alloys. The mixing of specific elements enhances its strength and corrosion resistance. Om Tubes being Duplex Tubes Manufacturers provides you with best quality & services
Miscellaneous Logo
monitor
If your LCD monitor has damage it could be in three forrmats:
1) Damage LCD ribbon. The screen will power up bright white and you will see random strings of color in diaganol or horizontal streaking slowly across your screen.
2) Damaged Liquid Crystal Container. The thin glass/plastic may have ruptured due to an impact on the screen. You will see sharp jagged lines and maybe a partial post screen, but where the sharp "jaggies" are, are now permantly broken
3) Nothing on screen. This indicates that your internal CCFL (oh I love LED technology) tubes have now lived their life and will not ignite. To test this method, hold a very bright light to the screen and see if you can see any logos (Compaq/HP/Win Xp loading screen...etc)
If you can see something, your screen is fine, but there is no light behind it for you to see.
Hope this helps.
Jun 05, 2008 | Compaq tc1000 Tablet PC
112 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
