Tip & How-To about Miscellaneous
Om Tubes 904L Pipe Fitting
904L Pipe Fittings are used in pipe systems to connect straight pipe or tubing sections. The main use of fitting is to make the pipe or the tube adaptable to different sizes or shapes. Om Tubes 904L Pipe Fitting Manufacturers are also used for other purposes such as regulating or measuring fluid flow. The term plumbing is generally used to describe conveyance of water, gas, or liquid waste in ordinary domestic or commercial environments, whereas piping is often used to describe high-performance conveyance of fluids in specialized applications. The term tubing is sometimes used for lighter-weight piping, especially types that are flexible enough to be supplied in coiled form. Om Tubes being 904L Pipe Fittings Suppliers provides you with best quality & services.
Miscellaneous Logo
fix copper tubing 1/2 " pipe
use pipe cutter to lop off end and sand the last 2-3 inches down with abrasive sand cloth. if you never braised before, i would recomend sharkbite plumbing fittings. comes in 1/2", which is what it looks like you have. it slides onto existing pipe (copper, pvc, cpvc and pex) and makes a seal, while the teeth inside keep it from coming off. there is a ring on the end that you can push in with a specific tool (which comes with some fittings) to remove it. they have extentions, valves, couplings and terminations in sharkbite. they sell them at any home depot. good luck and have fun
Feb 27, 2014 | Plumbing
123 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
