Tip & How-To about Miscellaneous
Om Tubes 254 SMO Valve
254 SMO Valve is a grade type of Stainless Steel and it is a very high austenitic type of Stainless Steel. It does have high levels of chromium, molybdenum and nitrogen, hence, it is especially suited for high chloride environments such as seawater beach plants and other process streams. It is a perfect material for stonewalling attacks from outer forces, pitting and crevice attack and chloride corrosion type of stress cracking. This grade is potentially stronger than any other austenitic grade because it is particularly characterized by high ductility and impact strength and also, it can be easily welded and fabricated. Om Tubes 254 SMO Valve is widely regarded has a cost-effective and perfect substitute for nickel and titanium alloys. If copper is added to the material, it improves its corrosion resistance and adaptability to more kinds of oxidizing acids. Om Tubes being 254 SMO Valve Suppliers provides you with best quality & services.
Miscellaneous Logo
what is the name or number of nonmagnetic stainlessteel ?
It is commonly stated that "stainless steel is non-magnetic". This is not strictly true and the real situation is rather more complicated. The degree of magnetic response ormagnetic permeabilityis derived from the microstructure of the steel. A totally non-magnetic material has a relative magnetic permeability of 1. Austenitic structures are totally non-magnetic and so a 100% austenitic stainless steel would have a permeability of 1. In practice this is not achieved. There is always a small amount of ferrite and/or martensite in the steel and so permeability values are always above 1. Typical values for standard austenitic stainless steels can be in the order of 1.05 - 1.1. SeeComposition effects on the magnetic permeability of austenitic stainless steels
It is possible for the magnetic permeability of austenitic steels to be changed during processing. For example,cold work and weldingare liable to increase the amount of martensite and ferrite respectively in the steel. A familiar example is in a stainless steel sink where the flat drainer has little magnetic response whereas the pressed bowl has a higher response due to the formation of martensite particularly in the corners.
In practical terms, austenitic stainless steels are used for "non-magnetic" applications, for example magnetic resonance imaging (MRI). In these cases, it is often necessary to agree a maximum magnetic permeability between customer and supplier. It can be as low as 1.004.
I hope this helps you
Marty
Jun 19, 2014 | Measuring Tools & Sensors
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Feb 17, 2012 | KitchenAid KSF26C6Xyy Side by Side...
stainless steel?
There are many (>100) standard stainless steel alloys. The most commonly used stainless steel alloys in appliances are "austenitic" - these have a higher chromium content and added nickel. The nickel modifies the physical structure of the steel and makes it non-magnetic.
Nov 04, 2007 | Kenmore 15073 Stainless Steel Built-in...
105 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
