Tip & How-To about Miscellaneous
Simple Fix
To save you time and aggravation of looking online to fix this problem or try to figure out something that is "frozen"; try this first. Everything is like a computer now. Cell Phones, Game Consoles, TV's, Programmable Home Cooking Appliances and even Washers and Dryers. Some of this you wouldn't even think of like that. When your phone freezes you pull the battery, when the game system freezes; you unplug it. The same goes with your computer. Well this little trick works just as well with washers and dryers sometimes; even works on coffepots and crockpots. Give this a try first as it will sometimes fix that problem.
Miscellaneous Logo
While playing marble Aggravation, a player had a "3" and a "4" on his dice. He wanted to move the "3" first, even tho he could move the "4". If he moved the "4" first, he could then move another marble behind, but he didn't want to. He claims it was his right to choose. Which was correct?
Thank you for your question. It appears you are playing a modified version of Aggravation. The original rules from Hasbro call for the use of one die. The player must move only one marble the full amount on the die. If the player can not move the full amount of the die, his/her turn is over.
Other keys to moving your marble according the the original directions are:
  • You can only move a marble out of the "base" and onto the "start" space with the roll of a 1 or 6.
  • You get an extra turn when you roll a 6.
  • You can jump over or land on an opponents marble (aggravate it) but can't jump over or on your own marble.
  • A "aggravated" marble (one that has been landed on) is to be placed back in the "base" area to be started over.
  • You can use the "star" and "center" spaces for shortcuts. However, the center space must be landed on and the roll of a 1 is the only way off the center space.
  • You must move all 4 marbles into the "home" area by the full roll of the die to complete the game.
Here is a link to the directions: http://www.hasbro.com/common/instruct/Aggravation_(2002).pdf. My personal opinion on your situation with the 3 and 4 dice rolls is that he could chose which marble to move 3 and which to move 4. But, the full use of the amounts of the dice must be used and the total on one die can not be split by two different marbles (a 4 die can't be split into a 2 and a 2).
Hope this helps and doesn't "Aggravate" you more! :0) Have fun playing!
Jan 22, 2011 | Toys
T9 Dictionary on Samsung SGH-A707
The only way to fix this is to completely reset your message memory. To do this, go to Menu -> Settings -> Memory Settings -> Clear Memory -> then click Messaging and OK. You will be prompted to enter your password. Enter it, confirm and you should have no problems.
Feb 24, 2009 | Samsung SYNC SGH-A707 Cellular Phone
283 people viewed this tip
Top Miscellaneous Experts
extremebill
Level 1 Expert
tlaloc
Level 1 Expert
Cedric Murphy
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
