Tip & How-To about Computers & Internet
How to disable password on login for Windows 10
This video will show you how to disable the password login on Windows 10
1. Press the Windows Key + R to bring up the run menu and type netplwiz to bring up the User Accounts dialogue.
2. untick the box that says that users must enter password.
I am not responsible for anything that happens on your machine and these tutorials are to be used at your own risk. If in doubt contact an IT professional.
Computers & Internet Logo
How do I set up my login to just tap the picture and not have to use a password
Going to assume win 8:
  1. windows key + R
  2. type netplwiz and press enter
  3. Select your account and uncheck user must enter pass to use computer
  4. enter your password to accept the changes.
Enable direct Windows 8 login without password prompt
Jun 19, 2015 | Computers & Internet
how do i unlock my dell computer home screen with out a disk
1. windows DVD installer
2. Boot from DVD and choice repair
3. Choice command promt menu
4. Type it: copy c:\windows\system32\sethc.exe[space]c:\ and hit enter
5. Type it: copy c:\windows\system32\cmd.exe[spasi]c:\windows\system32\sethac.exe and hit enter. Type exit and hit enter
6. Press CTRL+ALT+DEL to reboot from hard disk
7. On windows home screen, press Shift keys 5 times. It will activate command promt.
8. Type it: net user [your account] [your new password] and hit enter. Type exit and hit enter.
9. Now you can log in to your windows using your new password.
10. Don't forget to replacing back the sethc.exe or just leave it.
Sep 19, 2014 | Dell Latitude E6530
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
Aug 04, 2013 | Computers & Internet
410 people viewed this tip
David Payne
David Payne
