Tip & How-To about Computers & Internet
How to Reset Data Usage in Windows 10
This video will show you how reset data usage on Window 10.
1. Press windows and R key to bring up the run menu.
2. Type msconfig and hit enter.
3. Go to boot and select safe mode with minimal settings.
4. Once rebooted navigate to C:\Windows\System32\sru and delete all the files in this folder (DO NOT DELETE THE FOLDER).
5. Press the windows + R key to bring the run menu back up again.
6. Type in msconfig and turn of safe mode and restart.
7. Your data will now be reset.
I am not responsible for anything that happens on your machine and these tutorials are to be used at your own risk. If in doubt contact an IT professional.
Computers & Internet Logo
how do i unlock my dell computer home screen with out a disk
1. windows DVD installer
2. Boot from DVD and choice repair
3. Choice command promt menu
4. Type it: copy c:\windows\system32\sethc.exe[space]c:\ and hit enter
5. Type it: copy c:\windows\system32\cmd.exe[spasi]c:\windows\system32\sethac.exe and hit enter. Type exit and hit enter
6. Press CTRL+ALT+DEL to reboot from hard disk
7. On windows home screen, press Shift keys 5 times. It will activate command promt.
8. Type it: net user [your account] [your new password] and hit enter. Type exit and hit enter.
9. Now you can log in to your windows using your new password.
10. Don't forget to replacing back the sethc.exe or just leave it.
Sep 19, 2014 | Dell Latitude E6530
how do you get out of safe mode?
Safe mode is normally manually activated by pressing F8 at startup. However if it is stuck, you can try disabling it from the system configuration menu:
If using Windows XP:
1. Start the machine and boot to the Windows desktop.
2. Click Start > Run
3. In the dialog box, type msconfig and press "Enter". This will bring up the configuration window.
4. Click on the "Boot" tab and in the lower left corner under "Boot Options", untick "Safe Mode".
5. Restart the computer.
If using Windows Vista/7:
1. Follow the same instructions as above, however when you click Start, just type msconfig in the search box at the bottom of the Start Menu and press "Enter".
Jul 19, 2014 | Computers & Internet
When i start my computer i git this Running error LogitechDesktop Messenger.exe
1. hit win+R to open "run" command window. (or) open "Run" window from start menu.
2. type "msconfig" in Run window.
3. click "startup" tab in msconfig window.
4. hit "disable all".
Restart the computer, now you wont find that error.
Hope, its helpful.
Regards,
Baskar
Jan 06, 2010 | Yahoo Messenger
327 people viewed this tip
David Payne
David Payne
