Tip & How-To about Garden
2 cycle engine out of time
Hello fellow lawn people.....BEWARE!!!!....if you have hit a rock or root with your" gas powered" mower it's possible you have changed the engines timing which could have a drastic result ....it happened to myself and required complete" knock me out"surgery to reset the bones and install steel pins in my hand resulting in 6 weeks off work.....what i've learned is... if the shaft that the blade connects to the engine has changed position ....due to striking a solid object....the engine could then possibly be put out of time and could possibly backfire while pulling the startpull cord .if this happens the pullcord could be rapidly retracted resulting in a serious injury ...my advice would be to have the unit checked by an authorized technician if you experience a rapid retraction of the pullcord....goodluck....brian d.
Garden Logo
Pull cord hard to pull since I hit tree root
see if the blade is bent the check the key under the flywheel
Aug 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
when mower is cranked, the enigine spits and sputters and balck smoke comes out from the side.
Did you hit something hard with your mower; like a stump or a rock? It sounds like your timing may be off. There is a key under the flywheel that is designed to break off if you hit something so that it doesn't bend the crank shaft on your mower. If that key breaks off, your mower will go out of timing and spit, sputter and backfire when you try to start it. Best of luck to you.
James
Aug 25, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I hit a rock while mowing and now the mower is vibratating badly? What do I need to Do?
You bent the blade. Therefore you need to by a new blade and install it.
Good Luck!!!!
Wayne
Jun 14, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
204 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
