Tip & How-To about Miscellaneous
Socket weld fittings are family of high pressure fittings are used in various industrial processes .The Socket weld design is commonly used in the demanding environments of chemical and power plants. They are used only in conjunction with as me pipe and are available in the same size range. They are visually examined for conformity to ASTM, ASME, MSS, DIN, EN, and JIS codes and standards.
They are used for lines conveying flammable, toxic or expensive material where no leakage can be permitted, and for steam 300 to 600 PSI .They are used only in conjunction with ASME Pipe and are available in the same size range .They are used in areas where pipe-work is permanent and are designed to provide good flow characteristics.
They are produced to several ASTM standards and are manufactured in accordance with ASME B16.11. The B16.11 standard covers pressure-temperature ratings, dimensions, tolerances, marking, and material requirements for Socket weld carbon and alloy steel. Acceptable material forms are forgings, bars, seamless pipe, and seamless tubes which conform to the fittings chemical requirements, melting practices, and mechanical property requirements of ASTM A105, A182, or A350.
The purpose for the bottoming clearance in Instinox Socket weld Fitting is usually to reduce the residual stress at the root of the weld that could occur during solidification of the weld metal and to allow for differential expansion of the mating elements. Instinox being Socket weld Fittings Suppliers provides you with best quality & services.
