Tip & How-To about Miscellaneous
Instinox Super Duplex Pipe
Super Duplex Pipe is a chemical composition which is a mixture of approximately equal parts of ferrite and austenite. The mixture of these components makes the Super Duplex Pipe twice as strong as regular austenitic or ferritic stainless steel pipes. Instinox Super Duplex Pipe show excellent stress corrosion cracking resistance (SCC). Super Duplex Pipe are resolute and tough and can manage temperatures up to minus 80 degrees C. The strength of the Super Duplex Pipe makes it possible to weld on the thicker sections of the pipe. However, this should be done with uttermost care. These pipe offer high strength which in turn leads to weight saving. Compared to most pipes in the industry, duplex stainless steel pipes have one of the best price stability. Due to its low cost and weight saving, in the recent years Super Duplex Pipe have been growing in popularity as an alternative to nickel alloy based pipes. Instinox being Super Duplex Pipe Supplier provides you with best quality & services
Miscellaneous Logo
what is the name or number of nonmagnetic stainlessteel ?
It is commonly stated that "stainless steel is non-magnetic". This is not strictly true and the real situation is rather more complicated. The degree of magnetic response ormagnetic permeabilityis derived from the microstructure of the steel. A totally non-magnetic material has a relative magnetic permeability of 1. Austenitic structures are totally non-magnetic and so a 100% austenitic stainless steel would have a permeability of 1. In practice this is not achieved. There is always a small amount of ferrite and/or martensite in the steel and so permeability values are always above 1. Typical values for standard austenitic stainless steels can be in the order of 1.05 - 1.1. SeeComposition effects on the magnetic permeability of austenitic stainless steels
It is possible for the magnetic permeability of austenitic steels to be changed during processing. For example,cold work and weldingare liable to increase the amount of martensite and ferrite respectively in the steel. A familiar example is in a stainless steel sink where the flat drainer has little magnetic response whereas the pressed bowl has a higher response due to the formation of martensite particularly in the corners.
In practical terms, austenitic stainless steels are used for "non-magnetic" applications, for example magnetic resonance imaging (MRI). In these cases, it is often necessary to agree a maximum magnetic permeability between customer and supplier. It can be as low as 1.004.
I hope this helps you
Marty
Jun 19, 2014 | Measuring Tools & Sensors
102 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
