Tip & How-To about Miscellaneous
Extra Storage Tips
  1. Don't forget to use valuable space inside drawers and larger appliances, such as stoves and refrigerators, to store small items: towels, linens, toys, etc.
  2. Break down large items such as bed frames, tables, and large furniture, and don't forget to keep all parts (screws and smaller items) together by taping them to the item.
  3. Wrap furniture legs with protective bubble wrap, furniture covers or pads to prevent scratching.
  4. Label boxes on all sides for easy identification.
  5. Make sure fragile boxes are placed on top of heavier, less delicate boxes. Be sure not to over pack boxes as they can get heavy and dangerous.
  6. Place frequently accessed items towards the front of your unit. Less frequently needed items should be placed toward the rear of your unit.
  7. Boxes that are tightly sealed with packing tape will prevent dust from entering
Miscellaneous Logo
Kenmore refrigerator model # 596.75522400 bottom frizer. Frizer works ok but refrigeratot does no get cold.
If the freezer is cold, it is probably the evaporator fan motor or the damper. The damper is the easiest to check.
Inside the refrigerator compartment, top, center, back is a small plastic grill that snaps out of a larger plastic housing. Tug gently from the bottom edge. You should see a small damper door. If it is closed, push it open. If you feel a flow of air, the fan motor is good and the problem probably has something to do with the damper not opening. If you do not feel the flow of air, it is probably the evaporator fan motor.
If it is likely the damper, you can prop it open to get the refrigerator compartment cold again until you can solve the damper problem. I have not had to solve this problem yet, so good luck.
I've had problems with evaporator motors in every Kenmore appliance I've owned. So, it is probably the evaporator fan motor. The motor is just above the evaporator coils inside the freezer compartment.
Lift out the baskets and lift off the drawer front. Remove the drawer slide mechanism buy depressing a single plastic clip on each side as you pull the slide forward.
If you
Oct 23, 2010 | Refrigerators
need to take off u-line 2075 drawer refrigerator doors - how?
Hi
Frost in u-line drawer dwrr models happens because of 3 things. The most common is that the drawer wasnt sealing properly. At the ends of the slides you see a white plastic end. This is called door closers. Remove your drawers,Unplug the top drawer. Then remove the closers on all slides. Take a small screw driver then push on the top of the slide. You should see a piece of the closers. While pushing down pull the ends out.You see the hook and spring, sometimes the hooks get off track and keep the drawer from closing. By keeping them out this should help. Also if you have vegetables keep them in sealed containers. The 3rd thing is you have the display set at 34 and this will cause the unit to run 100% of the time. Recomend 36 degrees.
Jan 17, 2009 | U-Line Echelon Series 2075DWRRSS...
74 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
