Tip & How-To about Apple iTunes
How to change multiple songs on iTunes to have the same heading.
Select what songs you want to change either by holding down the shift key, command key, or by going to the top of your computer and pushing edit, at that point you need to hold down control and click on you computer a small tap will pop up select get info from that screen you will be able to edit whatever category you like the push go or enter.
Apple iTunes Logo
how to delete all songs at once, it only delets one at a time?
When its plugged into the computer, open "My Computer" and find your mp3 player in the list. Open it and navigate to the music folder. When you see the list of songs, left click on one you want to delete one time to highlite it. Then when you see more you want to delete just hold down the "Shift" key and you click on them. When all the ones you want deleted are highlited, push the delete key, not the backspace key. To delete all music, click on edit at the top of the windows and click "Select All". Then hit delete.
Jun 10, 2011 | Mach Speed Eclipse 180 MP3 Player
i dont know how to add songs to a folder in my computer
Click on "My Computer", select C drive then File "New Folder" then type in a title for the folder such as "My Music" then when ever you download tell the download site to download to this folder. This will make it so you can easily find your music folders. If you have the music on a Cd then open "My computer" select the drive with the Cd icon by right clicking on it and then selecting "explore" this will give you access to all the music files on the drive. Click on one of the files to select it, as indicated by a solid color change, then hold down the "shift" key on your keyboard and press the "down" arrow to select the rest of the files, then click "edit" "copy" then go back to My Computer and select the "C" drive and highlight the new "My Music" file and then click "edit" and "paste". This is just one method, a harder one in some ways, to copy files from a disc to the hard drive. From here you have the source of all the files for your "you tube slide show"
May 12, 2009 | Computers & Internet
Sound Problem with MAC OS X 10.4.11
This sounds obvious, but the system volume could be down. Go to the System Preferences, and select "Sound". Make sure the output voumne is turned up, and the mute is not on.
If that doesn't work you could try "zapping the pram".
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound again. Continue this until you hear the startup sound four times.
  6. Release the keys.
Apr 03, 2009 | Apple Mac OS X 10.4
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
417 people viewed this tip
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
