Tip & How-To about Miscellaneous
Diagnose Quicken printing problems
Quicken printing problem mainly happens due to problems with printers. Check whether your printer is turned on properly or not. If turned on, check ink status and cartridges. If everything is fine, go to control panel of your computer, and open Printer dialogue box. Check settings and find whether printing machine has been detected by your computer or not. If printer is not detected, restart your system to get rid of the error. Printing data files of Quicken Customer Support also shows errors, when you try to printed non-updated version of data file. Updating data file will resolve the issues with precision. For more assistance, call customer support team of Quicken.
Quicken Customer Service 1 800 406 3148 Care Number
Miscellaneous Logo
Cannot open printer from Quicken 2001 Deluxe
Check intiut's website. There have been some problems with 64-bit Windows Vista. You didn't specify whether you have 32-bit or 64-bit operating system.
Aug 09, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
won't print checks or anything from quicken but does for every other program. All I get is "spooling" and then nothing.
It won't print you have to save the file on the desktop or in documents or anywhere away from the original and then try to print.all printers have issues with quicken deluxe they will not print from quicken deluxe unless it so happens b fluke
May 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Re: PIXMAMP600 I am having trouble in some instances where I get a message on the computer that my printer is off-line. I am able to print other things without a problem. When I try to print a Quicken report it tells me that my printer is off-line. What is the problem?
I am not too familiar with Quicken as I use QuickBooks, but if I am right Quicken uses a printer service like Microsoft Word and QuickBooks does.
Look in the Printer Folder in Control Panel and look to see if a Quicken printer icon is displayed, if there is one, right click the icon and check the properties to make sure your printer and not Quicken is the default printer. I have actually deleted the Word, Quickbooks and Acrobat Reader printers in the past with no problems.
You could also check the Options in File. Open Quicken and in the top left corner click File, check to see if there is an Options tab or any thing regarding the printer to make sure your printer is the default printer and not Quicken.
Oct 03, 2008 | Office Equipment & Supplies
89 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
