Tip & How-To about Miscellaneous
How to repair a flat screen TV ruined by windex
After ruining my plasma TV screen with Windex, I was able to restore it by polishing the screen with Mequiars headlight restoration polish. Use a microfiber cloth and after a few applications, the damaged surface will be removed.
Miscellaneous Logo
How can I clean the headlight?
headlights can be restored using a headlight restoration kit easily found at an auto parts store or even walmart. You will want to look in the car care section. It will generally involve scuffing up the headlight and then polishing back to normal with a polishing compound.
Feb 27, 2016 | 2008 Buick Lucerne
Tried cleaning radio screen with goop off now its worse think I damaged plastic now white film can it be fixed
You may be able to use headlight cleaner/restorer on it to restore it. It works to remove yellowing and or hazing on headlights by scrubbing off the top layer with different grits of sandpaper then a polish to shine and protect
Oct 14, 2013 | Office Equipment & Supplies
How many gallons of compressed air will I need to clean 1 pair of headlights with 3M Pnuematic Headlight Restore System?
73 seankim,
You will need to get an Air Compressor. I assume it will take 100's (if not 1,000's) of gallons of compress air. Actual amount depends on how long you run the polishing tool.
May 30, 2009 | 3M ? Headlight Lens Restoration System #...
stainless steel doors need to be polished
I've personally been performing restoration of high end metal surfaces, bronze, stainless steel, aluminum etc., including scratch removal, polishing, regraining, lacquering etc.. Strictly commercial properties, elevators escalators etc. I've performed these services for 30 years. As a Master Finisher I developed DeBruce Polish, and still perform metal restoration personally.
go to debrucepolish.com
contact: Bruce Smith
Apr 16, 2009 | Kitchen Ranges
88 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
