Tip & How-To about Miscellaneous
Slow and poor battery charging - try a new USB lead.
Had my tablet about 2 years, noticed battery began to be very slow to charge and not holding good charge. Checked various forums which suggested such as accesing internal battery connection (after levering tab out of rear cover..not an easy task in itself!) Unplugging and replugging battery connection.. still no better. Also tried clearing cache data in storage. Tried factory reset.. still the same. Found another forum that suggested replacing original USB lead that came with tab and charger originally..bought a decent quality USB lead with correct end for tab.. and all good. Tablet charges to 100% smoothly and quicker than had become common situation. If you are having the same charging problems try a new USB lead.
Miscellaneous Logo
RCA Tablet won't turn on
my rca tablet won't turn on I tried charging but it's not working ...
www.tomsguide.com/forum/id.../rca-tablet-turn-charging-working.html
Oct 24, 2015 - 12 posts - ‎10 authors
I had this problem with my 8 year olds 7" RCA tablet. It's the Android 4.4 system. I did the following and it worked perfectly. Hold the on-off ... My RCA tablet won't Charge!!!! - Voyager
Nov 2, 2015
Help! My tablet won't turn on! what do I do?! - Asus
Oct 17, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
I have a RCA Pro 10 tablet that wont turn on. It was ...
May 29, 2015
More results from www.tomsguide.com
How to fix a RCA tablet that won't turn on - YouTube
? 0:55
https://www.youtube.com/watch?v=K1zOqKR85vA
Feb 22, 2015 - Uploaded by SkyDoesMinecraftRulez
It won't erase anything. ... How to fix a RCA tablet that won't turn on ... its all a lie I have ome and they don't ...
Nov 19, 2015 | HP Computers & Internet
the kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
I have an HP G60-235X that I purchased a little more than a year ago. About 6 months ago, I began to notice less charge life in the battery and a very high temperature from the battery pack. Now, and for the past 3 months, the battery doesn't hold a charge at all and when I do use my laptop (plugged in) the battery gets extremely hot to the point that it can cause skin burn.
You need a new battery. One or more cells is defective. Obviously it's unsafe to continue using a battery pack if it gets hot enough to cause burns, so remove the pack from the computer. You can continue to use the computer on AC power until you get a replacement battery.
You might try contacting HP to see if there's any kind of warranty accommodation they can make. I've found several mentions in various forums about batteries in similar models going bad and that HP replaced them, but they were all within a year of purchase. Can't hurt to ask, though.
Jul 09, 2011 | HP G60-235DX Notebook
126 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
