Tip & How-To about Hetman Partition Recovery - Recover Deleted Partitions
How to Restore Files From a Windows Image
Windows 10 OS provides ample opportunities for data backup which include tracking file history and functionality that allows creating an image of the entire system. The concept of the system developers is that the functions of File History are required for convenient and rapid everyday recovery of user data, while a system image is created not so often and allows complete recovery of a partition (including system files) to a certain operable OS.
It is recommended to create a backup system image copy before modifying the hardware configuration of a computer, when updating the system, installing new drivers and so on. If something goes wrong, a backup system image copy will allow you restoring the system to the operable condition of Windows. However, when restoring from such image all the information on the system disk is erased by the image files. What should we do if we need only some files to be restored from the system image?
Fortunately, this task is rather easy. The matter is that the standard system of creating a backup system image copy in Windows 10 is based on the concept of virtual disks (Virtual Hard Drive). That is, images are recorded and stored as virtual drive files in the format vhdx (Virtual Hard Drive). Such virtual drives can be easily mounted with standard features of Windows 10 and be operated as ordinary drives within the system. Attaching such disk to the system, a user can restore from the backup system image separate files and directories.
Connecting a VHD disk containing a backup system image copy
System image is usually backed up to a separate physical disk or a network folder. That is why the first thing to do is to connect to the computer a media containing a backup copy of Windows 10 image (or connect a network folder).
Open the computer management console Computer Management and go to disk manager Storage->Disk Management (this console can be launched from the menu WinX by pressing the key combination Win+X and selecting the item Disk Management). In order to mount a vhd virtual disk select the item Attach VHD in the Action menu.
In the window that appears click Browse and specify the path to vhdx file. This file is usually stored on a drive that contains a backup system image copy in the directory with a name in the following format [Backup_Drive]:\WindowsImageBackup\[PC_Name]\Backup xxxx-xx-xx xxxxxx. In our example, complete path to the vhdx file is as follows: \\[PC_Name]\VHD\08_01_2016.vhd.
After the virtual drive has been mounted it has to be assigned a drive letter. To do it, click the right mouse button on the drive and select the menu item "Change Drive Letters and Path".
In the window that opens click Add and assign any letter to the drive, for example, E:
After this operation, a new drive will appear in the system, to which letter E:\ is assigned. Open in with Windows Explorer or any file manager and find the files that need to be restored.
Advice. User documents (photos, videos, music and other documents are usually saved to user's profile in the directory E:\Users\{user_name}.
After you have found and copied the necessary files, the external disk can be disconnected and as a result, the virtual vhd disk will also disappear from the system. Separate files from the system image can be recovered in the same way in Windows 7 and 8 as well.
If suddenly happened the lost of VHD image of Windows (for example, accidentally or intentionally deleted) it can be recovered by Hetman Partition Recovery. After recovering it with data recovery software you can restore individual files by stated above algorithm.
Hetman Partition Recovery - Recover Deleted Partitions Logo
how to backup bauhnAAP5-815to win 10
Use the backup and restore within Win 10. Click Backup in the search box.
Nov 12, 2016 | Computers & Internet
How to Restore XP Backup Data in Windows 8 OS?
Microsoft offers file transfer support.
Apr 25, 2014 | Computers & Internet
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
how to backup windows 7 on acer aspire 5532
use "back on ur computer" option from control panel to take backup in windows 7
Nov 27, 2009 | Computers & Internet
245 people viewed this tip
Top Hetman Computers & Internet Experts
David Payne
David Payne
Are you a Hetman Computer and Internet Expert? Answer questions, earn points and help others
