Tip & How-To about Miscellaneous
Just the facts for a speedy answer
Although you may feel frustrated when you are trying to promptly fix a problem you may be having, we are also frustrated when there is not enough pertinent details to help us help you. Always remember to add important details to your question, so we may promptly help you.
Miscellaneous Logo
bmw 318 wont turn over then does turn when it feels like it only put a new starter into it help
check the earth wire, sometimes they are lose enough to be problematic. Although if turning over and not firing up, does sound like immobiliser issue. Are you using the master key? although I'm not sure about 1994, should deativate once unlocked with key, unless after market alarm set up
Apr 09, 2013 | 1994 BMW 3 Series
I have a problem in setting the tension of the machine. The upper thread is too tight although I adjust it to 1 or even 0. I try to clean the bobbin area and re-thread. Occasionally it works. Very frustrated.
Yes it can be frustrating, I believe that you have a tension prolem with the bobbin case.
The upper tensions should be 3 to 5 normally on your machine.
When you pull the bobbin thread do you feel any resistance? If not then you may need to check that you are threading the bobbin into the case correctly, re test
if that doesn't work then look for a little screw, turn it clock wise to create some light tension on the bobbin thread. Re test
If that fails take to local tech for repairs.
Best of luck chris
Feb 11, 2011 | Brother XL-3510 Mechanical Sewing Machine
My acer laptop is locked because the password is incorrect . How do i open the laptop without the password
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Recovery Tool .
4. Re-install. Will lose data.
Nov 23, 2010 | Dell Inspiron B130 Notebook
Oops! This link appears to be broken. I keep on receiving this message everytime I tried to add, delete, or change a photo on FAcebook. I tried to restart Facebook from scratch without success. This is getting very frustrating. Please advise.
Go to My computer -> Tools (at the top) -> Internet Options -> connections -> Click on LAN-settings -> Disable any checks there.
check it should be fixed now.
If still same, Try this:
Click All Programs -> Accessories -> Command Prompt
At the prompt type: ipconfig /flushdns
You should get a message that says:
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
One of these will fix it
Jun 10, 2009 | Facebook Social Network
68 people viewed this tip
Top Miscellaneous Experts
Helen Franco
Helen Franco
Level 1 Expert
Crash Moore
Crash Moore
Level 1 Expert
Edmund Perozzi
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
