Tip & How-To about Baby Gear
Benifits of Baby Gates?
Stair cases: The protection gates are installed near the top and bottom of the stairways so as to prevent any injury leading repercussions.
Kitchen: The protection gates are installed in cooking areas so that the kid does not easily enter into the kitchen as the place is not safe for a kid. https://www.babyandpetgates.com/wp-content/cache/wpfc-mobile-cache/index.html
Baby Gear Logo
stairway banister how to install
It would take me a lot of writing to tell you how to do it properly. The easiest way to find out is go to You Tube and type in
Stairway banister how to install
Feb 07, 2014 | Kid Smart Living KidCo Stairway Banister...
where should I install a smoke detector?
The National Fire Prevention Association (NFPA) states that the best location for a smoke detector is on the ceiling near a doorway or stairway.You should also have a smoke detector on the hallway ceiling outside of sleeping areas (bedrooms). Put one either inside or just outside the kitchen.
May 09, 2013 | Home
Have Ford E350 Cutaway Diesel. Apparently batteries are dead. They are located under the vehicle, behind the driver side. How are these batteries changed?
SECTION 414-01: Battery, Mounting and Cables 2005 E-Series Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 07/01/2004 Battery - Auxiliary adobe.gif Printable View (264 KB) Removal
ani_caut.gif WARNING: Batteries normally produce explosive gases which can cause personal injury. Therefore, do not allow flames, sparks or lighted substances to come near the battery. When charging or working near a battery, always shield your face and protect your eyes. Always provide ventilation. Failure to follow these instructions may result in personal injury.
ani_caut.gif WARNING: Keep body from under the auxiliary or secondary battery when disconnecting or reconnecting the auxiliary battery safety straps since the battery weighs 50 pounds and bodily injury can result. Failure to follow these instructions may result in personal injury.
  1. ani_caut.gif CAUTION: Failure to accurately follow the battery disconnect procedures described in this section may result in vehicle or component damage.
    NOTE: The preferred method of service requires the use of a floor hoist to lift the vehicle overhead, and a transmission jack to support and lower the auxiliary battery case.
    NOTE: The auxiliary battery can be charged while the auxiliary battery safety straps are connected to the vehicle. Follow the procedures up to and including disconnection of the auxiliary battery cables.
    Disable the vehicle electrical supply. For additional information, refer to Dual Battery Disconnect in this section.
  1. Remove the 2 auxiliary battery cable harness screws retaining the harness to the frame.
  1. Support the bottom of the auxiliary battery and case with a transmission jack.
  1. ani_caut.gif CAUTION: To prevent possible damage to the auxiliary battery case, cover the battery cables during the lowering process. It is recommended to loosen the auxiliary battery case cover bolts before lowering the battery box.
    Remove the auxiliary battery case from the frame.
    1. Remove the upper RH auxiliary case -to- frame bolt.
    1. Loosen, but do not remove, the 3 remaining battery case-to-frame bolts.
    1. Raise the battery case up and to the right to dislodge the battery case from the 3 remaining bolts.
  1. Lower the auxiliary battery and case until tension is present on the safety straps.
  1. Remove the 2 bolts and disengage the battery case cover.
  1. Remove the auxiliary battery cables.
  1. Remove the 2 auxiliary battery case safety strap to frame bolts.
  1. Remove the hold-down wedge.
  1. ani_caut.gif WARNING: When lifting a battery, excessive pressure on the end walls could cause acid to spew through the vent caps, resulting in personal injury. Lift with a battery carrier or with your hands on opposite corners. Failure to follow these instructions may result in personal injury.
    Support the battery and case with a transmission jack. Disengage the safety straps and roll the auxiliary battery and case on the transmission jack away from the vehicle.
Jul 19, 2011 | 2005 Ford Econoline Cutaway
stair case wiring circuit
Could you describe your situation a bit more detail? are you asking about 3 way switching on a stairway?
Please vote !!
May 04, 2010 | Prime 10 Amp Circuit Breaker
553 people viewed this tip
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
