Tip & How-To about Miscellaneous
Advantages of using Online Appointment Scheduling
  • Make it work like you do: You can enforce appointments to fall inside opening hours and outside holidays. You have detailed control over what information is entered with each appointment and you can specify who gets notified when something changes.
  • Control access: You decide who gets to see your schedule and who can make changes to it, with finely grained details such as how long in advance appointments can be canceled.
  • https://visibook.com/
Scheduling software and app for professionals and clients
Miscellaneous Logo
What is an acceptable noise level on a Sunday and the hours that they are permitted to make such a noise outside with machinery
Check with your local law enforcement to see if there is a noise ordinance in your area. If it's during daytime then most likely there isn't though.
Mar 12, 2017 | The Computers & Internet
appointment@hrdcall2011.com this site not open how to read my details
I PING'd the website; the server is not responding, so you should wait 12 to 24 hours to see if the problem gets fixed. There is not much you can do when the web server crashes...
Best of luck with this; be patient and try again tomorrow. With a little luck, everything will work properly within a day or two...
Apr 25, 2011 | Computers & Internet
I HAD A PAPER JAM, HAVE REMOVED THE OBSTACLE BUT NOW IT WON'T SHRED
monaswan, If the motor refuses to run, unplug from wall outlet. Then let it "cool down" outside for about 1 hour. Then try it again. There is a "temperature sensor" inside unit that "opens-up" and will not let it run until the ambient temperature falls to a safe operating area. Reply after 1 hour and let me know if that was solution!!! 12fixlouie
Aug 20, 2010 | Royal Office Equipment & Supplies
Refrigerator not cool enough in garage.
if the unit is not in an area that falls below 65 degrees f then he is wrong, if the unit is in an 80 degree envorment then there is a problem with the unit possible sealed system leak 1st i would check, second a defrosting issue third fans running
unit can be serviced in the garage, the tech is incorrect
May 27, 2008 | Kenmore 60721 Refrigerator
240 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
