Tip & How-To about Miscellaneous
How to store supa glue
Keep super glue in fridge after opening , it stops it from curing ready to use again.
Miscellaneous Logo
my fridge part the door handle keeps coming loose
Most of time just a stripped screw or fitting on door handle so you have to replace whatever part is missing or broken. Rich
Apr 13, 2015 | Refrigerators
how to replace rear rotar
Just the rear rotor itself? Or the motor as well?
Tail rotor pops right off, and replacement will pop onto the shaft easily. A small, very carefully applied, drop of super glue will keep tail rotor on firm. If doing that, I recommend you turn the helicopter upside down and then pay close attention that you don't get any glue near where the shaft meets the motor, and don't turn it over again until glue is totally dry.
If the motor needs to be replaced, you'll need soldering equipment, it's a really simple wiring job, but the wires are barely thicker than a hair and not very easy to access. Not recommended unless you're very confident with a soldering gun.
Hope this helps,
r
Jan 03, 2011 | SYMA Toys industrial Syma S032 Ready to...
super glue stuck on fingers
To remove the supper glue from you skin you need to Immerse bonded areas in warm, soapy water. Peel or roll skin apart; a spatula or teaspoon handle or even a pencil will help. Remove cured adhesive with warm, soapy water (may take several applications). Fingernail polish remover with an acetone base has also been successful for removal of cured adhesive from skin.
Good Luck
Aug 22, 2010 | Health & Beauty
the alarm goes off by itself and the fridge will stop working. switch it off for two to three days and it work again for few days
switch fridge off and defrost it 24hrs. inside fridge remove panel and locate the flap on the thermostat. put something behind it to jar it open about half inch. restart fridge and see if it cures problem. if it does fridge thermostat requires replacing. jaring the flap open is only a temporary fix to diagnose problem. but i did mine 4 months ago and still fine
Aug 05, 2010 | Zanussi ZX97 / 5 Bottom Freezer...
printer problem Officejet K60
dry the section thats bad use a little super glue to apply both ends together after you open ink cartridge
you will get messy so i sugest old clothes newspaper and some disposable gloves once you have the ink ribbon glued back together let dry in fridge for about 4 days sinces its cold its going to take a little longer for glue to dry but wont dry out the rest of the ribbon
this is the only eldest way since typewriter days this has been the simple fix of printer ribbons
make sure to always keep back up ribbon so your work doesnt fall behind
Jun 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
122 people viewed this tip
Top Miscellaneous Experts
Rick Oudette
Rick Oudette
Level 1 Expert
Richard Daly
Richard Daly
Level 1 Expert
Dale
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
