Tip & How-To about Computers & Internet
Mac Data Recovery After OS X Mavericks Upgrade for External Drive Data
The popular OS X Mavericks upgrade has garnered one strong complaint from many Mac users in that they have experienced the loss of data as a result. This most often occurs for those who used an external hard drive or Western Digital software application. The result has been an inability to access the external drive or the loss of specific data.
The good news is that the uFlysoft can exercise a Mac files recovery effort to access your external drive and bring back your deleted files.
How uFlysoft Works
In order to get the Mac data recover that you want, the first step is to not save, reformat, or do anything that might make the data loss a permanent one. You will want to use the uFlysoft system first.
Uninstall Western Digital Software: If you have this on your system, you can uninstall it and restart your computer. It is possible that you may be unaware of its presence on your system, but check to see if it is there and then remove it.
Add uFlysoft: Here, you add the software to the system for your Mac trash recovery efforts and install it on your computer.
Transfer Files: When the files are recovered through uFlysoft, transfer them to a safe storage place such as another, unaffected drive so that they can be accessed properly.
Add External Drive: Now you can connect the drive that was damaged and a second one to copy the files.
When you launch the software, you'll notice a list of drives that you can choose from on the screen. Click the name of the drive that was affected and scan. Here, you can make the appropriate changes to correct the damage that has been done. This means rebuilding partitions that may have been damaged or removed, engaging in Mac data recovery, and seeing the files being returned to your system. If you engage the uFlysoft shortly after the Mavericks upgrade, the quick or standard scan should be enough to recover the files. If not, a deeper scan will be necessary.
Review Data
You'll want to look at all the Mac files recovery to see if everything is there. This will mean previewing all the appropriate files and running your drive to ensure that everything is okay. A double-check will ensure that the Mac data recovery has worked and your software has restored all the files after the Mavericks upgrade. For those who have yet to upgrade using Mavericks, it is recommended that you backup all of your files first so that they can be reinstalled in case the data is lost.
You will want to report the loss of the data to Apple so that they can take note and create steps so that others will not be affected by the upgrade. Although Apple is aware of the issue, every report of lost data is crucial to their attempts at finding a remedy. With uFlysoft, you can restore the files lost during an OS X Mavericks upgrade and save what you have thanks to the advanced Mac trash recovery system.
RE:
Computers & Internet Logo
Why Mac OS X Mavericks is so much terrible in memory management? Can anyone tell me how to optimize it?
Hi John,
Millions of users are using Mavericks edition of Mac OS X. That's perfect for most, but some users claim slower Mavericks performance.
If you are also some of them, then here are some of the helpful tips which improve the system performance.
1. Update Apps: After installing Mavericks, run the software updates. You should do this to ensure that all the Apple software is running as per the latest version.
2. Check your Apps: Not all the available application in the system comes from the Apple App store. It is also possible some 3rd party apps eating system resources and as a result, it degrades the performance of Mac Mavericks.
3. Check Activity monitor and console: If things still run slow, then launch Activity monitor and Console.
Activity Monitor will show all the apps which consume more CPU resources and you can take appropriate step against those resource consuming apps.
Even, after trying these above written steps, the performance of Mavericks doesn't improve, then use software. You can give a try to Stellar Speed Up Mac or any other.
Jun 30, 2015 | Apple Computers & Internet
how do i removing yahoo net safety from a mac
Download the App "AppCleaner.app"
Drag your Yahoo app to the "AppCleaner" icon
It will find all the associated files connected with the Yahoo item. Then just delete.
But.... Your machine looks like it might be in need of a full update?
Use this tool to see if your Mac can handle a Newer OS X.
Mactracker
This will give you all the tech info on your Mac
If Maverics is acceptable and you have say 2gb of RAM!
Then, Download the free Maverics OS X first.
Prepare an external USB Hard Drive (or Partition)
Try doing a full Clone Backup with CCC to the External HD
When finished Prove that the Clone is Bootable.
Use Option Key on Reboot. If OK
Use Drive Utility to Erase Internal HD ready for a clean install.
Then install a new clean OSX10.8 (Maverics) to get your machine almost up to the latest with a cleaned up pristine Mac HD.
Use Migration Assistant to return only the data files you want or just drag the "User" folder across by hand.
(Migration will bring back the Yahoo Software)
Mac Backup Software
OS Mavericks 10 9 Download
Sep 01, 2014 | Apple Leopard 10.5 Osx Mac Operating...
Mavericks problems
Apple doesn't allow going back unless you reformat the drive and load the last OS you were using. This is of course not practical but there is some 'good' news... Apple is (as they always do) coming up with a fix that will solve many of the problems your are having w/ Mavericks.
Just a note... With Apple its always best to wait a couple months after a new OS release before you take the leap. The same thing happens virtually every time with Computers, Phones etc. Waiting allows them to fix the mess they are putting early adopters through and you get to load a stable OS.
Nov 10, 2013 | Apple iMac Computers & Internet
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
  • Xserve (Early 2009)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
Oct 23, 2013 | Computers & Internet
478 people viewed this tip
David Payne
David Payne
