Tip & How-To about Konica Minolta Office Equipment & Supplies
Konica Minolta 1580MF Toner Reset Code After Refilling
1. Open the front door
2. Press Clear button
3. Press Start button
4. Down Arrow and Up Arrow
5. Press OK
6. Close the Front door
Press the Button Continuously as per above mentioned.
konica minolta 1590mf i replace toner still asking replace toner
Ready to copy
Oct 03, 2016 | Konica Minolta Office Equipment & Supplies
Can't get it to auto tune
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
install the correct print head
You can clear the errors in your printer in three reset procedures.
Reset it manually
1. Turn off the printer
2. Press and hold the Resume Button, an indicator light green
3. Press and hold the Power button
4. While holding the Power button, release the Resume button
5. While holding the Power button, press the Resume button twice
6. Release the Power button
7. Press the Resume buttons four times
8. Press the Power button to confirm the operation
9. Turn off the printer
Reset canon mp600 to factory setting (if the first procedure did not work)
1. Press the Home button
2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press OK button.
4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset Settings, then press the OK button.
5. Use the Easy-Scroll Wheel or the up/down arrow to select Yes on the confirmation screen and then press OK
6. Press the HOME button to return to the Home Menu
Final reset (If errors did not clear and or another error appears this will clear it)
1. Press and Hold the Resume button and wait until the printer self restart.
2. Release the Resume button when the printer restart
3. Wait until the printer fully initialize and try printing again.
That will solve it.
Please comeback and give some ratings.
thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How do I reset drum counter on brother printer HL5250dn
Hello. if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Regards, Joe PS: kindly rate my answer. Thank you.
Jan 28, 2010 | Computers & Internet
5,742 people viewed this tip
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
