Tip & How-To about Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364)
How to Fix SQL Server Fatal Error 823
Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364) Logo
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times.
Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF.
After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode.
Finally go ahead and execute DBCC CHECKDB like this
DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS
More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version...
http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/
https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
May 15, 2015 | Microsoft SQL Server 2008 Enterprise Full...
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
how can i fix the problem by error message 262,level 14,state 1,line 1 CREATE DATABASE permission denied in database 'master' in sql server 2005
RecoveryFix for SQL server database recovery utility is a very powerful utilty to fastly short out your all problems to MS SQL database. By using this application, user can simply repair SQL database. Read more: http://www.sqlrecovery.org/download.html
For more information read this post: http://diskdatarecovery.jimdo.com/2013/07/23/how-to-restore-lost-data-on-server-while-running-sql-server/
Jun 22, 2010 | Microsoft SQL Server 2005 Enterprise...
Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-7813.html
and here is Microsoft's information
http://support.microsoft.com/kb/313178
Jan 03, 2008 | Microsoft SQL Server Standard Edition for...
578 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
