Tip & How-To about Miscellaneous
How To Install V-checker Iobd Module B342 ?
How To Install V-checker iobd module B342 ?
https://eforshop.en.alibaba.com/product/60466962000-803036757/V_Checker_iOBD_Module_B342_OBD2_Diagnosis_Interface_for_IOS.html
V-Checker iobd module B342 are suitable for all OBD standard cars which manufactured after 2001, with the connection between Bluetooth and module B342. Users can acquire vehicle condition (Speed, Coolant temperature, Engine speed, Fuel consumption, etc) & various of real-time warning (DTC, Over-Speed, high coolant temperature, fatigue driving) with installing APP on mobile phone.
Step1: unpack the V-checker iobd module.
Step2: Find the OBD connection in your car, It usually located under the steering wheel, above the brake pedal if you cannot find it ,Please contact your local 4S dealer.
Step3: Turn on your ignition key, start your car, keep your car under idle mode.
Step4: Plug iobd module into OBD socket correctly the indicate will keep flashing, System will scan vehicle protocol automatically for 2 minut.
Step5: Run V-checker APP, initialize the iobd module settings refer to the steps on the screen.
Checker iOBD Module B342 OBD2 Diagnosis Interface for IOS
Miscellaneous Logo
How do you prevent accidental overdose on medications?
Read the information sheet that comes with boxed medicine. For medicines without the sheets, everything is available online. To prevent accidental overdose, you follow the instructions and dosage carefully.
here are a few good sites
**** Interactions Checker - For Drugs, Food & Alcohol - Drugs.com
https://www.drugs.com/drug_interactions.html
**** Interactions Checker. In order to proceed to the **** Interactions Checker, you must read and accept the following terms: The Service is a service provided to you by Cerner Multum, Inc. (" Multum"). The Service and the Drugs.com internet website are separate products provided by separate entities.
**** Interaction Checker - WebMD
www.webmd.com/interaction-checker/ This tool may not cover all possible **** interactions. Please check with a physician if you have health questions or concerns. Although we attempt to provide ...
Multi-**** Interaction Checker - Medscape Reference
reference.medscape.com/****-interactionchecker **** Interaction Checker. Use the search field above to look up prescription or OTC drugs, and herbal supplements; Add a full **** regimen and view ...
**** Interactions Checker - Check Your Brand and Generic Drugs ...
www.rxlist.com/****-interaction-checker.htm Conversely, when a ****'s absorption is reduced by food, the **** is taken on an empty stomach. **** interactions that are of greatest concern are those that reduce the desired effects or increase the adverse effects of the drugs.
**** Interaction Tool ' University of Maryland Medical Center
umm.edu/health/medical/****-interaction-tool Check for potential interactions between drugs with this **** interaction tool.
interactions Google Search
Mar 14, 2017 | Miscellaneous
need diagram for how to re install flywheel
Hi ! for an informantion, please visit the website below. If you need more information about a specific electrical issue you can reach me at motor@motorpartstore.com.
May 13, 2016 | Arctic Cat 2005 400 4x4 Automatic
73 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
