Tip & How-To about Office Equipment & Supplies
How to take care in order to Use Fixed Sustainable Printer
Use the printer regularly, so try to use the printers every day. Because using the printer regularly will keep the flow of ink remains good so as to wet the nozzle where the discharge of ink. Rawat printer regularly and try to test the printer once a week.
Maintain the cleanliness of the printer, besides taking care of your printer's performance should also clean the printer regularly. At least twice in one week. Move the printer away from dusty, so use either the protective plastic or cloth in order to avoid dust.
Replacing printer ink, this should be done if the ink is about to run out. So, do not let lack of ink because it could make the printer into error. It should be noted when replacing a cartridge part because this part is very sensitive so do not touch the electrical cartridge with a finger. Clean using a delicate tissue. This will make the cartridge to be more durable and long lasting. (See: How to Fill Ink Printer with True )
Turn the printer off when not in use, after use do not forget to turn off the printer. Turn off the printer correctly by pressing the power button (on / off) on the printer. Do not turn off the printer by unplugging the power cord, but simply pressing a button on / off. Because by pressing the power button, the printer will automatically perform surface cleaning head before the device is off.
Use a clean paper, to print either text or image you must use a clean paper so that the printer is still durable. Because, when using paper dust and dirt can make the pickup roll becomes dirty and over time will lead to faster wear so that the printer was broken.
Canon MAXIFY iB4000 Driver Download Printer Review
Have a canon printer (i9900) & the message I'm getting: "waste ink absorber is almost full". What does this mean & what do I do?
Hi
This is a regular maintenance required you to take the printer to service centre to replace the ink-pad present in the printer. Follow the below instruction to keep working with the printer as normal.
First of all remember that these measures are then by the company for protection of ink overflow.
If you can spare some time try to take the ink pads out of the printer and wash them thoroughly so no ink remains in them and then do the below instructions.
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain in green.
3) Press resume button 4 times (Green) for Waste ink counter reset.
4) press the power button. The printer will switch itself off after performing the function.
Then you are ready with the printer to work.
PLEASE RATE MY SOLUTION
THANKS
Jun 29, 2011 | Office Equipment & Supplies
the printer keep asking for ink replacement. the cartridge ink is half full. how can i use the remaining ink if the printer wants to replace a new ink. plz help
You take on the cartridge and you get the cartridge into the printer to put a mid-trough, where they see the chicken trough of ink cartridges.In the middle of the cartridge put tape and the printer see the cartridge full and you can use the remaining ink.If i have been useful please give me a vote :).Thanks
Apr 13, 2011 | Brother MFC 240C All-In-One InkJet Printer
new ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
I cant print any paper out. it dosent work. something wrong with the paperhead. ive tried to clean up all printer but it dosentwork anyway. to print out pics on a cd works triffic. bt i want to print out photos and regular text paper to. im getting almost angry at this looosyprinter who dosent work.. Gah!
If it prints photos but not regular (black) text. This means the black ink is not flowing at the nuzzle. This usually may not be resolved by just running printer ink head clean up.
What you should do is take out the black ink cartridge, press a folded tissue paper to the nuzzle (where the flows from); if it comes out blotted with ink, it is OK. if not, that's the cause of the problem. So place it in a plate/saucer/bowl with a bit of water so that the nuzzle part is all touching water. Leave it for about 10 minutes. take it out and press a folded tissue paper to it. The tissue should be blotted with black ink. You may need to repeat procedure till the blot is good enough/the flow is good enough. Then return it to the printer and print again.
Dec 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
533 people viewed this tip
k24674
