Tip & How-To about Miscellaneous
Camper fridge not working?
OK it's camping time again and most average campers don't know that they must clean the burner tube on a 3 way fridge and occasionally replace the electric element 40$ part with a high quality replacement once in a while... problem will happen like so, first your fridge will work when it's cool but not so good when it's hot... time to pop the out side vent and clean the burner tube... it has very fine holes that plug with soot. Actually most of the times once it is cleaned all you will get out of it is about the equivalent of a few specks of black powder but, that is enough to stop those fine holes from lighting properly. The tell is this once the burner is lit it should have even clear blue flames with no color changes, such as yellow flickers, if not it needs cleaning .. usually caused from parking not quite level when using... next is the short chimney... it has to be cleaned... if it is working on gas but not electric then your heater element is gone... most look like a long thermometer and must burn at around 315c... if it is out by 15 percent either side it is no good... remember even some new aftermarket ones don't make the grade so buy manufacturer built replacement... they have been tried tested and true.. cheap fix for an expensive fridge... I have personally gotten fridges going in 20 min that were supposed to be thrown in the dump according to the repair man... ones that are not worth fixing are any you see yellow powder around the condenser... means it's leaking.. refrigerant and is going to cost as much to repair as a new fridge..
Miscellaneous Logo
Dometic RV fridge will not stay on while traveling
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 22, 2010 | Dometic RM2652 Refrigerator
my propane fridge will not get cold
You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
The chemicals can become seperated in the wrong areas of the interior components.
Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
If the burner is working correctly, then you should see some results.
Oct 30, 2009 | Refrigerators
camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
100 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
