Tip & How-To about Miscellaneous
How to remove Run DLL Error on Startup
We normally face this problem that an error pops up whenever it wants
This normally happens because of some scheduled tasks in the operating system that you are unaware of .
Install Autoruns let it scan then find the exact path (as in your first post) and delete it. Reboot and see if you get the error message.
In order to scan these unattended , hidden tasks , please follow the below mentioned link to scan the Windows Sysinternals . And the file which is showing the error mostly shows up highlighted in yellow colour so its easy to identify .
https://technet.microsoft.com/en-gb/sysinternals/bb963902.aspx
Extract and run the application .
Delete the file that you get in Yellow Colour by the error and delete it .
Restart your computer and see if the problem is resloved .....
Miscellaneous Logo
When I try to schedule a task I receive this Error A6A3B6B2-1EA5-4C5A-BD20-3E6A6A8E429B and it says THE TASK IMAGE IS CORRUPT OR HAS BEEN TAMPERED WITH.
Contrary to the above answer, you absolutely CAN use the task scheduler to power down your computer.
Your task scheduler is corrupt, and needs to be rebuilt.
You will need to edit the registry to fix this problem.
Follow the instructions via the link below, 1st answer @ the top of the page.
http://answers.microsoft.com/en-us/windows/forum/windows_vista-performance/task-image-is-corrupt-or-has-been-tampered-with/91c0aef2-fa32-4795-8eb2-5c109cabe550?auth=1
1. Back up your registry FIRST.
http://windows.microsoft.com/en-us/windows/back-up-registry#1TC=windows-7
2. Navigate to the key, HKLM\SOFTWARE\Microsoft\Windows NT\Current Version\Schedule. See image below.
3. The schedule key will have several subkeys located on the right side of the registry window. Single click on the Schedule key on the left of the screen, and you will then see all of the subkeys display on the right side of the window. Delete all of the subkeys on the right side of the window (ONLY), and reboot your computer.
4. Test by scheduling a task.
Mar 20, 2016 | Microsoft Windows 7 Home Premium 64BIT...
Error when scheduling a task
I came up with a temporary fix by changing the Run as: from "Toshiba-ea\Toshiba" to "NT AUTHORITY\SYSTEM". This allowed me to schedule the tasks accordingly. Note that I still do not know the password for Toshiba!
Oct 27, 2009 | Computers & Internet
Windows 2003 Server Task Scheduler Exit Code (1)
Have you tried to use robocopy.exe instead of copy? Robocopy have a logging option and is a lot more powerful. It's available in Windows Server 2003 Resource Kit Tools.
May 26, 2009 | Microsoft Windows Server 2003 Enterprise...
error message on my Dell laptop Inspiron 5100
A task has been left behind by the Paretologic Program in the task manager's files that is responsible for this annoying error..to fix ..go to START ..ACCESSORIES .. SYSTEM TOOLS ..click on ..SCHEDULE TASKS and delete any tasks that concern Paretologic
Feb 27, 2009 | Dell Inspiron 5100 Notebook
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Dec 30, 2008 | Microsoft Windows XP Professional
65 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
