Tip & How-To about Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364)
Shrink SQL Server Transaction Log File
Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364) Logo
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times.
Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF.
After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode.
Finally go ahead and execute DBCC CHECKDB like this
DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS
More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version...
http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/
https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
May 15, 2015 | Microsoft SQL Server 2008 Enterprise Full...
Is it good idea to repair sql file?
Bulk Logged will not help you in this situation. Your transaction log is growing because you are performing large transactions. In simple mode, the log is truncated after a checkpoint.
Check these site: http://www.sql.recoverytoolbox.com/ & download demo Recovery Toolbox for SQL Server.
Depending on how you are loading your data, you may need to break it up into smaller chunks. Make sure you are not loading all the data in one large transaction.
Read more: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/380-is-it-good-idea-to-change-simple-recover-model-into-bulk-logged-on-etl-system
Nov 06, 2014 | Microsoft SQL Server 2005 Standard Edition
whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
635 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
