Tip & How-To about Miscellaneous
SAF 2507 instrumentation fitting
Super duplex is a grade that was developed over 70 years ago to be used in the sulfite paper industry. This grade came to be known as super duplex because of its mixed microstructure of about equal parts of ferrite and austenite.Super duplex tube fittings are manufactured to especially fight extreme corrosion problems which occur due to exposition to chloride bearing cooling waters and other aggressive chemical process fluids. Super duplex tube fittings have an extremely high mechanical strength which is one of the reasons that has made it ideal for use in onshore and offshore environments in oil and gas applications. These tube fittings not only have a high resistance to pitting, but also have an outstanding resistance to stress corrosion cracking at moderate temperatures. All Super duplex tube fittings also have an extremely high tensile strength compared to that of conventional austenitic stainless steels.
Super Duplex tube fittings are used in the following industries:
·Flowline pipe / line pipe
·Riser tubes
·Manifold piping
·Christmas tree piping
·Hydraulic lines for drilling risers
·Offshore oil and gas exploration and production.
·In heat exchangers in petrochemical and chemical processing.
The grade is also suitable for instrumentation applications in tropical marine environments
still we are not aware of it
to know more about it
http://instinox.com/tube-fittings/duplex-stainless-steel-tube-fittings/
Miscellaneous Logo
84 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
