Tip & How-To about Miscellaneous
PSA BSI Tool for peugeot and citroen user video
PSA BSI Tool V1 2 For Peugeot And Citroen KM Tool Mileage Programmer
Miscellaneous Logo
My fans radiator fans are not coming in my 1996 Jetta 2.0L, on what do i check first
It's possible that the pressure relief has failed & is venting (hissing) below the rated pressure for the cooling system; replacing the radiator cap & properly filling the system will probably solve the problem. Let it cool first to avoid injury.
PSA BSI tool for Peugeot and Citroen Odometer v1.2
Dec 13, 2012 | Cars & Trucks
just replaced the radiator and the jeep overheated after 1 month
It could be a bad thermostat or a water pump that is not pumping coolant. Even a miss routed serpentine belt causing the etc
Dec 13, 2012 | 1999 Jeep Wrangler
should dodge fuel pump shut off after a few seconds when key is turned on
The only way to stop power coming from your battery is to manually unhook it, it is always sending power if not dead.
Hot PSA BSI tool for Peugeot and Citroen Odometer High Quality
Dec 13, 2012 | Dodge Ram Cars & Trucks
3,976 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
