Tip & How-To about Office Equipment & Supplies
Broken Lead Stuck in Mechanical Pencil Sharpener
I had a broken lead jamming up the hole in a ipoint orbit mechanical pencil sharpener. This is what worked for me. You will need a long sharp needle or a straightened out paper clip. Alternatively, you can get a pick and hook test probe in a hardware store for less than $4. Loosen up the donut cap and remove the shavings collector. Now, you will be able to see the drill-like thing that rotates and sharpens the pencil. Hold it down. It depress a bit and gives a little bit of wiggle-room. Now, use the needle to jiggle around the broken lead. Give it a few tries...it will loosen up. Tilt the sharpener body upside down and gently tap, it will fall right off! Good Luck!
How do I change the blade on a iPoint evolution pencil sharpener?
Have you tried unscrewing the small circle that you insert the pencil into? Once that part comes off the blade should be more exposed.
Jun 10, 2013 | iPoint 15509: Evolution Axis Pencil...
Ipoint sharpener not sharpenning
Computers don't come with pencil sharpeners.
May 20, 2013 | Computers & Internet
won't sharpen end of pencil
Check for a broken piece of lead down in the sharpener by the rotary blades.
Dec 14, 2012 | Stanley BOSTITCH EPS11HC Quiet Sharp 8...
416 people viewed this tip
k24674
