Tip & How-To about Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364)
How To Fix SQL Server Error 5171
This informative video shows you SQL Server Error 5171 reasons and different methods to the error
Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364) Logo
How do I recover data from .mdf file
Detach you database. Overwrite the mdf and ldf files you've restored from your backup with your files from the D: drive. Reattach the database.
There is no guarantee that this will work or if it works, that your database is in a state where you can continue to work with.
If that doesn't work then there is an option to try to restore database using SQL Server Recovery Toolbox. It is a powerful tool for data recovery. They have a demo version. So you can check it works in your situation or not.
http://www.oemailrecovery.com/sql_repair.html
Jan 19, 2016 | Microsoft SQL Server 2008 Enterprise Full...
Recover data from corrupt .mdf and .ldf files.
You can find more information here:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Open your SQL Server Management Studio console. This application shortcut is available in the SQL Server directory in the Windows Start button.
· Enter the system administrator user name and password. SQL Server's administrator user name is "sa." This account is required for privileges to restore the database. If your restoring on a host provider server, use the administrator user name and password they supplied for your account.
·Right-click your database name and select "Attach." In the new window that opens, click the "Add" button to open a dialog box.
·Select your MDF file and press the "Ok" button. It may take several minutes to restore the database if it is a large file. Once the process is finished, browse your tables to verify the data. The database is now restored.
If nothing helped try to use:SQL Server Fix Toolbox
http://www.fixsqldatabase.com/
Nov 28, 2014 | Microsoft SQL Server 2000 Standard Edition...
SQL Server does not exist or access denied
check your firewall or the sql server machine firewall.
Jan 06, 2009 | Microsoft SQL Server 2005 Standard Edition
Connecting of SQL Server and .net
TITLE: Connect to Server
Cannot connect to KRISHNA-02E4A78\SQLEXPRESS.
ADDITIONAL INFORMATION:
Login failed for user 'KRISHNA-02E4A78\Guest'. (Microsoft SQL Server, Error: 18456)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&EvtSrc=MSSQLServer&EvtID=18456&LinkId=20476
BUTTONS:
OK
Jan 10, 2008 | Microsoft SQL Server Standard Edition for...
554 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
