Tip & How-To about Miscellaneous
Specifications of the Carbon Fiber Tube
Compared with the traditional materials such as steel, aluminum, wood, plastic, carbon fiber performance is more superior, it is very light weight, high strength, high rigidity, resistance to acid and alkali salt and organic solution of chemical corrosion, waterproof, low thermal expansion coefficient, high X ray transmittance, friction resistance, and thermally conductive, can design is strong, often combined with resin plate, pipe, mechanical parts and other products used in many fields. This article, small make up to introduce to you of the specifications of the carbon fiber tube.
1, According to the different shapes can be divided into round tubes, square tubes, rectangular tubes, elbow, tee, pipe can be used to kite skeleton, cases, bags, and X exhibition stand, scaffolding, special pipe is generally used in structure.
2, According to the different surface texture is twill, plain weave, not three kinds of grain. Some people think that is the carbon fiber surface has compiled grain, in fact, some carbon fiber products and metal is without grain.
3, According to the use of raw silk can be divided into different 1 k, 3 k, 12 k, etc.1 k said 1000 documentary silk is contained in a beam of strand, 3 k 3000 12000 root root, 12 k, most of them are on the market is 3 k.
4, According to the production process can be divided into different winding pipe and pultrusion. Resin pipe is dipping strand winding, winding on the mandrel, mixed curing unceasingly, this kind of method to produce products of good quality and beautiful appearance, but high to the requirement of equipment; Pultrusion tube is strand after impregnating resin through die extrusion, after completion of production does not need after processing, high efficiency, suitable for mass production, but the performance is less than the coil tube.
According to the needs of actual use, the flexibility to the carbon fiber tube design into various styles.Its long life, no matter in the humid, hot or corrosive environment can be normal use, for decades is not damaged.With the development of era, the demand of it will be more and more.
Best Carbon Fiber Tube for Sale Carbon Fiber Tubing Manufacturer
Miscellaneous Logo
What is the difference between traditional and modern Nunchakus?
Traditional Nunchaku was typically made from hard wood, such as oak. The modern Nunchaku can be made from wood, as well as other plastic and fiberglass materials. Also, the rope of the traditional Nunchaku was made of horsehair, while the rope of modern Nunchaku is made of nylon or metal.
Sep 09, 2012 | Martial Arts
Which pole is better, aluminum or carbon fiber?
Carbon fiber poles is light weight and are considered to be better than aluminum pole although their prices are much more expensive than the aluminum poles.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
What are the different materials that arrows are made of?
Most of the traditional arrows are made of wood. There are also arrows made of aluminum, Carbon, and Carbon fiber.
Aug 26, 2012 | Betsey Johnson Archery
Should I get an aluminium bike? Steel? Titanium Etc?
First off, let's be clear about "steel". There are cheap bikes made of "steel" or "high-tensile steel". Avoid these; they're outrageously heavy and not particularly durable.
When bike shops talk about "steel", they're usually talking about an alloy of steel, chromium, and molybdenum (and probably some other metals in small quantities). It may also be called "cro-mo", or "cro-moly". These bikes tend to be quite tough, though they might be a bit heavier than aluminum at the low-end. Cro-mo bikes are known for a "plush" ride, i.e. they absorb some of the vibrations of riding on rough trials. They can also be welded if they crack. Light rust can be a minor problem, but cro-mo bikes certainly don't rust like car fenders!
Aluminum has become the standard for mid-range and high-end bikes. They tend to be relatively light, and a lot stronger than one might expect (given that most people's experience with aluminum is Coke cans). They probably do bend more easily than cro-mo, so make sure you get a good warranty (good brands should have lifetime warranties). If they crack, special equipment is needed to weld them. Traditionally, aluminum bikes have been considered "stiff", and don't absorb the vibration of rough trails, but they seem to have gotten better in this regard. Some aluminum tubes bend rather easily, so take this into consideration of you ride in rocks a lot.
Titanium bikes have come down in price, to where they are now somewhat reasonable for a high-end recreational bike. They combine the plushness and durability of cro-mo with the lightness of aluminum. Titanium is extremely difficult to bond; take effort to ensure the builder is a good one.
Carbon-fiber mountain bikes are also light and extremely plush. They are tougher than one might expect; if they are solid material, they can stand up to a pounding with a sledgehammer. Some full-suspension bikes have hollow carbon-fiber bodies, and can break or have a hole punched in them by a sharp rock. When carbon-fiber fails, it fails suddenly and spectacularly. It may not be a good choice for heavier riders, or anyone who rides frequently in rocks.
Dec 16, 2010 | Cycling
53 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
