Tip & How-To about Apple Watch
How to disassemble apple watch
Compatible with 42mm Apple Watch
S/M Band fits wrist sizes between 130mm-180mm. Extra M/L Band is included that fits wrist sizes between 160mm-210mm ensuring a great fit for everyone.
High Performance Fluoroelastomer for Apple Watch® with 316L stainless steel alloy pin.
The smooth and soft material drapes eloquently across the wrist and feels snug and subtle on the skin.
The engineered pin-and-tuck mechanism makes sure you get a clean fit, every time.
No hassle, super easy to remove the old one and replace with this one. No tools needed.
For Disassembling procedure Follow the link
http://electro-medical.blogspot.com/
Apple Watch Logo
I have bought citizen watch JR3080-51L , and I need some more links because I got a watch that is good for 7" wrist and I need 8.5" wrist. Thanks
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Sep 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    how do I reduce the size of a metal watch band to fit my wrist better
    mcdevito75 here, You"d need a special tool called a link pin remover, BEST BET, look for a small watch repair shop in your area, hold onto the extra links once removed as you may need them again.
    Jul 12, 2010 | Watches
    542 people viewed this tip
    Top Apple Watches Experts
    Mik Dee
    Mik Dee
    Level 1 Expert
    Ravi
    Darren Neal
    Darren Neal
    Are you an Apple Watch Expert? Answer questions, earn points and help others
